I wanted to say that I have stock exhaust manifolds but tht is it. it goes from there to 2 1/2" all the way back to Dynomax Ultra Flo mufflers. How about the "WORLD PRODUCTS SPORTSMAN 2 CYLINDER HEADS" Anyone use them or have a coment.
www.ryanscarpage.50megs.com/combos1.html Check this site out. Has a lot of comparisons using different head and cam combo's for street engines. Aluminum heads allow you to run more compression with lower octane fuel, better cooling, less weight.
Okay let me get this right!
Vortec Heads (stock)?
Preformer Intake
A Cam with somewhere in the 450 lift and no more duration that 270
Timming Chain Set
Roller Rockers
Rebuild my QJet
Should give me 350HP?
How about Dart Iron Eagle or World Sportsman2 Heads?
I found some World Product Sportsman 2 Heads for $600.00 would it be worth it over the vortec?
I am using the World Product Sportsman 2 on my build, but I am not done with it yet. From my understanding, I believe they are similar to the Dart heads and, at one time, were manufactured by the same company.
The World Product heads flow better than the Vortec heads, but they also have a 200cc runner, rather than the smaller 170?? on the Vortec. The 200cc runner may be too big for your application unless you also are going to change pistons.
So I've looked and found these tell me what you all think and how much HP they will make and if it is god for me?
*Comp Cam/ Lifters/ Timing, Hydraulic Flat Tappet, Advertised Duration 265/ 269, Lift .442/ .465, Chevy, Small Block. $207.95
OR MORE CAM?
*COMP Cams Pushrod Guideplates $22.88
*Pushrods Heat treated set 16 $34.99
*!.5 Roller Rockers $155.00
*Upgraded Vortec Head Kit, Edelbrock Performer Intake with gaskets, bolts. This kit features our upgraded Vortec heads which have been modified to accept our high performance Z28 valve springs with lightweight LT4 retainers. This produces a high reving cylinder head that can handle up to 0.525" lift hydraulic camshafts. An Edelbrock Vortec Performer intake manifold is matched with this kit for optimum performance. $995.95
Total $1416.77
Along with my TH400, 3.55 rear 2 1/2" true duals with Dynomax Ultra Flo mufflers and rebuilding my Qjet or a Holley 600. $269.95
I'll need some center bolt valve covers hep me there.
So Let Me Hear It!
I think you need more cam with your compression and a 3.55 gear. Especially with iron heads your DCR could be too high with a 218 intake duration @ .050. Need to check it and try to tighten up the quench with a steel shim head gasket to avoid detonation. The XE 268 H might work better and I think it will be fine with a stock convertor and a 3.55.
OR MORE CAM?
Total $1416.77
So Let Me Hear It!
Check your selection of roller rockers with the hydraulic cam you listed above...
What you have above, but with hydraulic lifters and a comp cam XE268 is the setup I have...Just got it back on the road after the rebuild recently. I am still adjusting the timing and the carb, but I love it!!! The tires start spinning when I drop the clutch at about 1800 RPM!!!
The center bolt valve covers with the Chevy Bowties on them will run you about $100 new, or go to the junkyard or ebay and find them cheaper!!!
From: Wilmington DE, Drive it like you stole it, 68 327 4 speed coupe
Originally Posted by jackson
Aluminum Brodix Iron Killer heads ... IK180 or IK200 ... $1000-$1100/complete pair at summit. If your $1K-$1.5K budget is for Alum heads, cam, intake, gaskets, rockers etc ... forget it for now. On other hand ... L48 can get alot out of any set of small chamber (~64cc) iron heads, a $70 summit cam&lifter kit & thin shim felpro 1094 gasket ... raised compression & more cam does a lot. A good used set of Alum 58cc L98 vette heads, same $70 cam & thin composition gasket would set it on fire.
when i went through this a month ago these are what I landed on
OR MORE CAM?
Total $1416.77
So Let Me Hear It!
If your rocker arms are in good shape use them changing to
1.5 roller rockers on an engine with very low spring pressure
hydraulic cam springs is just a waste of your money. Your
750cfm Q-jet will more then do the job, if you want to go to
a holley get the 670 avenger, vacumm carbs work well on
modest cammed engines and auto trans.
Have you verified with Edelbrock that the Performer Intake will fit under your stock hood? While putting together equipment list, I seem to recall a problem but it might not have been that model.
From what I've read here on the forum and been told the Preformer will fit under the hood. But not the Preformer RPM I hope I'm right maybe someone will reply for sure.
Edelbrock tech support has gotten a lot of grief in various posts lately. I shot them several emails and always got replies within 24 hours. Trying to get through on the phone was useless. You might try asking them.
I just did some searching through old emails and it was the RPM Airgap manifold with a Q-Jet that wouldn't fit.
I am quoting directly from the '07 Edelbrock catalog I picked-up 2 weeks ago at the Gatornationals.....
PERFORMER AIR-GAP #2601 & #2604, carb height: 4.32" - Will not fit under stock Corvette hood
PERFORMER VOTREC #2116, carb pad height: 4.57" - Will not fit under stock Corvette hood
PERFORMER RPM AIR-GAP #7501, carb pad height: 4.72" - Will not fit under stock Corvette hood
PERFORMER RPM #7101, carb pad height: 4.72" - Will not fit under stock Corvette hood
Of the above listed intakes Edelbrock is telling us, in their-own catalog, that ANY RPM, vortec, or Air-Gap intake won't work with a stock Corvette hood, while no mention of clearence-problems is made regarding the 'straight' Performer intake, #2101:
if someone can get a carb-pad height dimension from an intake that DOES clear their stock hood, we'd know what pad-height is acceptable.
What do you think if I put the Vortec Head and intake set up on my 77 with 1.6 rockers and headers and a stage 2 Q-jet carb with out the cam? And then when my engine needs to be rebuilt do the whole thing cam flat top pistons etc. Would this help me with HP or do you think it would not be worth it.
Thanks for the help.
What do you think if I put the Vortec Head and intake set up on my 77 with 1.6 rockers and headers and a stage 2 Q-jet carb with out the cam? And then when my engine needs to be rebuilt do the whole thing cam flat top pistons etc. Would this help me with HP or do you think it would not be worth it. What kind of HP increase do you all think?
I think the L48 cam in a '77 is too wimpy to make it worth while...if you are going to do the heads, do the cam!!! Plus, then what are you going to do, reuse all of your old, worn out lifters? If so, keep them in order!!!
I know that the Performer manifold fits under my '77 hood with a drop base air cleaner...I was told the Performer RPM does not fit, ergo why I didn't get one...
