Help Me Pick New Heads
Old Mar 30, 2007 | 01:03 PM
  #41
69vettester's Avatar
69vettester
Originally Posted by GlockGuy
On the Summit sight I found Brodix 11sp x, 11 std x and 18 degree heads. Which of these are the 1K 180/64 youall are referring to.
Don
Don, Type in Brodix IK 180 in the summit search Box. IK for "Iron Killers"
Old Mar 30, 2007 | 04:20 PM
  #42
VictoriaVette's Avatar
VictoriaVette
I just got off the phone with the tech dept at SDPC and they told me that the performer intake has a carb height of 4.05" the vortec performer 4.57" vortec performer rpm 4.72" and vortec performer rpm airgap 4.72". So it looks like the vortec performer is only .502" say 1/2" taller. I have a friend of mine that told me he has a performer rpm intake on his 77 Vette I'm going to his house tonight to see for myself. I'll post what I see later. If he has the performer rpm I have no problem with what I want to do.
Old Mar 30, 2007 | 04:29 PM
  #43
GlockGuy's Avatar
GlockGuy
Thanks, after reading this thread I am thinking of pulling me reworked 76 heads and going with the Brodix Iron Killer heads.
edit*
All right I found them. For you that have them did you go with the DUAL valve springs or the SINGLE valve springs???
Old Mar 30, 2007 | 10:04 PM
  #44
VictoriaVette
I went by and checked on the 77 that my friend has it has a performer intake with a Holley 650 and a 3" K&N filter. It fits under the hood no problems. It was not the rpm intake!
Old Mar 31, 2007 | 02:13 PM
  #45
jackson's Avatar
jackson
Thanks, after reading this thread I am thinking of pulling me reworked 76 heads and going with the Brodix Iron Killer heads.edit*All right I found them. For you that have them did you go with the DUAL valve springs or the SINGLE valve springs???
YOUR Spring choice depends entirely upon which cam YOU have ... clearly spell out the details of YOUR cam and someone can make a recommendation. ie Hyd/solid ... flat/roller ... with lift & duration numbers. No need to write a book ... just the cam type & specs.
