Help Me Pick New Heads
Old Mar 27, 2007 | 10:54 PM
VictoriaVette's Avatar
VictoriaVette
Default Help Me Pick New Heads
I was thinking about putting a aluminum intake and a new set of heads along with a cam in my 77 L48 I do not want a race engine just more than the 180HP I have. I have a TH400 and 3.55 rear I do not want to have to go with a different stall convertor. Give me your ideas and what you think the HP/Torque will be.
Old Mar 27, 2007 | 11:05 PM
SIXFOOTER's Avatar
SIXFOOTER
How much you want to spend?
My choice is AFR 180
Old Mar 27, 2007 | 11:06 PM
VictoriaVette
What do you all think about these?
http://cgi.ebay.com/ebaymotors/Alumi...mZ320096768184
TortureTest's Avatar
TortureTest
Intake, heads, headers all good....be careful when choosing a cam, any decent mechanic / performance parts shop can give you sound advise on cam. Too lumpy and yer in for hell, a mild street rod cam should do the trick !
You should expect for little money to easily gain 30-50 horsies !
Old Mar 27, 2007 | 11:09 PM
TortureTest
One last thing, edelbrock sells what they call performance packs at reasonable rates.
www.edelbrock.com
then search performance packs and they outline expected horsepower gains etc.
Old Mar 27, 2007 | 11:10 PM
VictoriaVette
If I have to spend a lot I will just go with a crate engine from GM or maybe a T&L Engine. Maybe $1000.00 to $1500.00
Old Mar 27, 2007 | 11:39 PM
63mako's Avatar
63mako
St. Jude Donor '08-'09
Originally Posted by VictoriaVette
The heads are cheapies, the intake probably won't clear a stock hood and the cam has too much duration for a stock convertor. A set of Brodix IK 180's 64 cc is around $1000 new. Good head for the $. A 268 duration hydraulic cam is probably good on DCR, will be streetable, work with your stock convertor and provide good vacumn.$200 An edlebrock performer will clear your hood. $120. A nice set of full roller rockers $150. Under $1500 and you will get a lot nicer setup than the E-bay deal. These parts can be used later on a good short block if you trash that L48.
Old Mar 28, 2007 | 03:26 AM
Glensgages's Avatar
Glensgages
http://www.sdparts.com/catalogsdparts.aspx
..... not-aluminum, but the smaller chambers will raise your compression, making more power right-off-the-bat, and allow for more performance if you slide a cam in the motor later:
http://www.sdparts.com/product/SD806...merIntake.aspx
Old Mar 28, 2007 | 07:34 AM
jim2527's Avatar
jim2527
www.edelbrock.com
I'm a person who believes in buying matched sets designed to work together......
http://www.jegs.com/webapp/wcs/store...dkey=ClickInfo
I dont think any of the intakes will work with a stock but not 100% sure......
Old Mar 28, 2007 | 07:47 AM
VictoriaVette
I do not want to have to change my hood so I do not think the Preformer RPM will work. Someone said RPM's. Also the link to the heads from SDPC did not work it got me to the site but did not show the heads you were talking about.
Old Mar 28, 2007 | 07:55 AM
Glensgages's Avatar
Glensgages
..... the link to the heads from SDPC did not work it got me to the site but did not show the heads you were talking about.
..... the first SDP link above shows several head/intake kits, while the 2nd link features upgraded valve-springs (permitting .525"-lift cams ) on vortec heads, and an Edelbrock Performer intake:
I believe this will show the heads with upgrade -
http://www.sdparts.com/product/SD806...ngUpgrade.aspx
Old Mar 28, 2007 | 08:06 AM
L88Plus's Avatar
L88Plus
I'm a firm believer that just about any caveman could come up with a better group of parts than Edelbrock offers. Their heads - big block and small block - flow mediocre at best. For about the same money, you can get a set of Brodix or Dart heads, a good Comp or Crane cam (cams are the sorriest part of Edelbrock's packages) and an intake that will fit under your hood.
If you're on a tighter budget, rework a set of Vortecs with a little bowl blend and short turn clean-up. Pick a cam with under .475 lift - there are several out now made specifically for this situation - and get a Vortec intake that will fit under your hood and you'll have a permanent grin for well under your budget. There'll probably be enough for some cheap ceramic coated headers to help it breathe and dress up your engine compartment.
Old Mar 28, 2007 | 08:37 AM
Edzred72's Avatar
Edzred72
200cc intake runners are too big for what your looking for. 64cc chamber is good to raise compression. The cam lift spec is ok, but duration is too much. Crosswind intake is RPM Airgap clone that wont fit under your hood.
My opinion:: Much better combos out there for your purpose. I modded a 77 a few yrs back very similar to your needs. Stay with a 180cc runner 64cc chamber head. Stay under .490 lift 230 duration cam (using 1.6 rockers on intake valve) & a good dual plane intake with headers. 300HP will be easy, and will have GREAT driveability. Mine was!!!
Eddie
Old Mar 28, 2007 | 09:03 AM
jackson's Avatar
jackson
Aluminum Brodix Iron Killer heads ... IK180 or IK200 ... $1000-$1100/complete pair at summit. If your $1K-$1.5K budget is for Alum heads, cam, intake, gaskets, rockers etc ... forget it for now. On other hand ... L48 can get alot out of any set of small chamber (~64cc) iron heads, a $70 summit cam&lifter kit & thin shim felpro 1094 gasket ... raised compression & more cam does a lot. A good used set of Alum 58cc L98 vette heads, same $70 cam & thin composition gasket would set it on fire.
Old Mar 28, 2007 | 01:04 PM
coolerthanethan's Avatar
coolerthanethan
same issue here except i need to figure out heads and cam for a 350 with a 4 speed. was looking at the edelbrock package but seems popular opinion says otherwise
we already have an edelbrock performer intake which we would like to use along with comp 1.5 roller rockers, and a edelbrock 600cfm carb
the car is running through hooker side pipes
so if i were to jump on the brodix 180's which seem like a good set of heads at a good price which cam would you guys recommend to get at least or as close to 400hp out of the combo?
Old Mar 28, 2007 | 02:09 PM
69vettester's Avatar
69vettester
IK 180's would be hard to beat for your application w/ performer height Intake .
A dual pattern cam in the 262 or 268 advertized range, Comp Grind Number XE268H if you can rely on your compression ratio being up above 9 to 1.
If you cant rely on at least that compression ratio drop down to a XE262H Grind. Crane has comparable cams, research and make your choice . Either one Use as thin a Head Gasket as will work. All surfaces flat and very clean. Also 1.6 rockers will give you a reliable little bump up and still be in range with the smaller 180cc intake runners.
Tom
Old Mar 28, 2007 | 03:00 PM
VictoriaVette
I had a 74 Z28 with a TH400 3.73 rear and all I did was put some headers and a 750 holley and it ran like a bat outa Hell! If I could get my 77 to run like taht I would be happy. How did GM build a 350/350 with no headers? I know the comp. was higher but with small chamber heads I should be able to do some waht the same. Let me here back from you all.
To Help Me Pick New Heads
Old Mar 28, 2007 | 03:46 PM
Little Mouse's Avatar
Little Mouse
The exhaust system on a 77 is a real killer for performance and the
more power you try to make with the engine the more of a
restriction it becomes, keep the exhaust manifolds if you do not like
headers but do something with the mess back behind the manifolds,
the 350 horse older vettes did not have to contend with the lousy
exhaust system you have, they also had a small dome piston and
64cc heads good compression to make the 220s at .050 int. duration
cam work. You can make 350 hp with your dished pistons with 64cc
modern iron heads for a little less money then aluminum and that
would give you extra money to spend on getting rid of the exhaust problem. The rpm manifold will fit under your 77 hood no problem as
long as you are willing to use a drop base air filter not the stock filter.
Get rid of the L/48 cam it has 195/202 at 050 duration and 390/410
lift.
Old Mar 28, 2007 | 03:58 PM
63mako's Avatar
63mako
You said it in your post. All an engine is is a big air/fuel pump. The more in and out, the more power you can produce. The holley and headers let more in and more out. The 373 gear helps transmit that power to the pavement. The 350/350 was 11 to 1 comp with a big hydraulic cam. It also had 2 1/2 inch ramshorns. They were also rated different.
64 CC heads, 268 cam, headers with 2 1/2" exhaust and a good intake will put you where you want to be in power. The Brodix IK 180's as recommended above are a good choice. The dual pattern XE 268 H is the cam to use with your setup. Chevy's like a little more on the exhaust side which the dual pattern gives you. What goes in has to go out. Look at the difference in intake and exhaust valve sizes. Rebuild your quadrajet and set your distributor timing and advance correctly you will have added I would guess 80 to 100 HP at the crank.
Old Mar 28, 2007 | 04:01 PM
VictoriaVette
I wanted to say that I have stock exhaust manifolds but tht is it. it goes from there to 2 1/2" all the way back to Dynomax Ultra Flo mufflers. How about the "WORLD PRODUCTS SPORTSMAN 2 CYLINDER HEADS" Anyone use them or have a coment.
