please define "fully assembled heads"
Old Mar 29, 2007 | 02:59 AM
supercalvin's Avatar
supercalvin
Default please define "fully assembled heads"
Does the term "Fully assembled Heads" mean I can just pull off my current heads and bolt the new ones on?
Assuming I have gaskets, sealant, and tools.
I don't have the knowledge or background to assemble a set myself.
In the near future I'm thinking of replacing the stock 77 L-82 heads and possibly intake with something else. If this is do able with very basic skills I would rather do it myself. The emission gear has already been removed by a previous owner.
The 'what' I will be replacing them with is still a unknown.
Old Mar 29, 2007 | 03:06 AM
427CPE's Avatar
427CPE
= COMPLETELY ready for installation.
Old Mar 29, 2007 | 06:29 AM
Fevre's Avatar
Fevre
Everything but the rockers
Old Mar 29, 2007 | 11:20 AM
JPhil's Avatar
JPhil
Have them checked by reputable machine shop before you put them on: I know of several sets of "ready to go" heads (including my own) which had seats not completely sealing or other small problems. It is well worth the extra $ to know they are truly ready to run.
John
Old Mar 29, 2007 | 11:39 AM
King Lear's Avatar
King Lear
Veteran
John
Also make sure you have the correct springs on it for your camshaft, I have known people who bought assembled heads with too much spring pressure and wiped there cam lobes. You will also need to learn how to check push rod length. I doubt the new heads will use the same length pushrods.
Old Mar 29, 2007 | 01:50 PM
JPhil's Avatar
JPhil
Originally Posted by King Lear
Also make sure you have the correct springs on it for your camshaft, I have known people who bought assembled heads with too much spring pressure.......
That happened in my case also. I had to change them out before installation. Luckily my pre-bought pushrods were OK.
Old Mar 29, 2007 | 02:08 PM
dmaaero's Avatar
dmaaero
Pretty much means valves and valve springs are allready installed. You might want to check the phrase "works right out of the box"
Old Mar 29, 2007 | 04:03 PM
marshrat99's Avatar
marshrat99
IMO at least disassemble, lap the valves a little and reassemble. I purchased a set of assembled Darts a few years ago and noticed the locks were just thrown on.
To please define "fully assembled heads"
