dash removal question
Old Oct 13, 2001 | 11:15 PM
70 LS1's Avatar
70 LS1
Default dash removal question
I have been able to remove the left and right sides before. I am having some difficulty getting the upper dash out. it seems to be catching on something. Can the upper dash be removed without removing the windshield?
Old Oct 13, 2001 | 11:47 PM
theandies's Avatar
theandies
Default Re: dash removal question (70 LS1)
Yes it can. Do you have the center console gauge's out? There is a screw the holds the wiper switch housing up that screws into the upper dash pad. There also is a screw on the passenger side close to the middle that needs to be removed. There are clips that go under the lower part of the windshield frame. I can't remember if the defroster vent is secured with anything, might want to check your AIM. I have also found that if you remove the A piller post moldings the dash pad come out ALOT easier. I alway check my AIM before doing interior stuff because you never know where :chevy hides screws and fasteners.
Good luck
John
Old Oct 13, 2001 | 11:50 PM
70 LS1's Avatar
70 LS1
Default Re: dash removal question (theandies)
Thanks, I'll go check it out.
Old Oct 14, 2001 | 01:48 AM
Jim Shea's Avatar
Jim Shea
Even with the A-pillar post padding removed there is still some interference. Some further ideas are to heat the pad with a hair dryer, a heating pad, or leave the car out in the sunlight. This should allow the pad to bend a slight amount and clear the A-pillars.
Old Oct 15, 2001 | 12:47 AM
theandies's Avatar
theandies
Default Re: dash removal question (Jim Shea)
Oh ya I forgot to mention that the pad will need to be bent a little to clear the a-pillers....thanks Jim
John
To dash removal question
