A/C noob need advice!
Old Apr 1, 2007 | 12:54 PM
jerome1979's Avatar
jerome1979
Originally Posted by BBShark
Sorry to ask this again but I can't be the only one who does not understand the designations for C3 compressors (A6 etc.). From an uneducated eye (mine), it seems that two styles of compressors were used on C3's. The longer, smaller diameter "early" style and the "later" shorter larger diameter style. Which one are you guys talking about and what is the designation for each? The original poster seems to have a 1979. Does it come with this style compressor?
I have this compressor "in" my 1979 ("in" because i remove it)
Old Apr 1, 2007 | 01:07 PM
kaiserbud's Avatar
kaiserbud
Hi Noonie - sorry - I think I misread/misunderstood your response.
If I understand correctly, the first statement applies to the condensor and the 2nd applies to the evaporator.
You are not suggesting to use, but to just view the Caravan or Mercedes condenser
On the evaporator, obviously, you are saying to just stick with the stock one.
Now that Natron company is the only ones that make Smart VOV's?
Old Apr 1, 2007 | 01:21 PM
noonie's Avatar
noonie
You'll have to switch to a 77 and later evaporator that uses a oriface tube expansion device instead of the poa setup. Both are plate types.
You can use any PF condenser as long as it fits in the space. The caravan uses block type fittings vs the more standard oring type. If getting a used one get the lines with it so it is easy to have adapter lines made for your car. Only buy used if it has pressure in the system when you look at it.
Old Apr 1, 2007 | 01:35 PM
BBShark's Avatar
BBShark
St. Jude Donor '05-'07
OK, last time I will interject but the original poster appears to be located in France. It also appears that he has the later R4 (?, still not sure of the designation) compressor and would like to re-install and restore the operation of his AC.
Although it seems the A6 compressor is superior, I'm not really sure that he has access to the components necessary to convert his system to the A6 compressor. Maybe someone could recommend a manual for him? The GM Corvette Shop Manual for 1979?
Old Apr 2, 2007 | 12:52 AM
kaiserbud's Avatar
kaiserbud
So i have remove my A/C last year on my 1979 but i would make it work again! but in this i'm a neewbie
so i need advice !
how to check my compressor?
what part i need to chage?
witch refigerant?
oil!?
thanks!
You're right BBShark.... I do not have a 79 AIM either In Noonie's input, there were answers on how to check the compressor and system, which parts can be used, to use R134a. The articles also designated which oils to use.
I also kept these links on my favorite lists - Jerome might consider that as well....
http://www.aapak.com/
http://www.ackits.com/
http://www.autoacforum.com/categories.cfm?catid=2
http://www.aircondition.com/vov/
Old Apr 2, 2007 | 12:32 PM
jerome1979's Avatar
jerome1979
Thanks a lot!
bbshark: i already have a 1979 shop manual
ps: i'm realy on the bad side of the ocean
Old Apr 2, 2007 | 06:10 PM
kaiserbud's Avatar
kaiserbud
I don't know Jerom.... I was there (Europe) for the first time last October - it really oopened my eyes to the world. Awesome place.... especially Italy.
Old Apr 3, 2007 | 04:14 AM
jerome1979's Avatar
jerome1979
for the next time you go in France we can have a beer together!
it's right for any corvette forum membre
Old Apr 3, 2007 | 11:31 PM
kaiserbud's Avatar
kaiserbud
sounds good
Old Apr 9, 2007 | 11:31 PM
kaiserbud's Avatar
kaiserbud
Noonie.... ok - question......
You noted that the original "plate type" evaporator is as good as it gets and are available new for a little over $100.00 and not $300.00 plus from specialty venders.
My current evaporator is a Harrison - I assume it is original - see pics of it in this post....Evaporator Assembly.
Can you offer more details on the purchase of an evaporator? I checked Autozone and O'Reiley's for one and they do not show any. Now - that being said, I know I am not going stock - so should I be looking for another model year to accomodate no expansion valve? Also - any comments on brands..... Is GM worth a visit for this (in my opinion) critical part due to its difficulty in replacing?
Old Apr 10, 2007 | 12:47 AM
noonie's Avatar
noonie
Here is an evap from a 78 vette.
http://www.ackits.com/merchant.mvc?S...t78corvette5-7
Basically what you want to do is to replace everything in the engine compartment to a 78 or later setup. For a compressor use either the a6 or a Sanden or other axial piston compressor. For a condenser use a parallel flow. You will end up with a cycling system that will be optimized for 134a.
The thread that you referred to was an old poa system, which really is better than the oriface tube, but years ago you could buy a poa valve new for 60 bucks and today they are not available. Oh well!
You can piece this together for much less than a complete aftermarket system and reatain most of the stock parts.
Old Apr 11, 2007 | 10:26 PM
kaiserbud's Avatar
kaiserbud
Hi Noonie - did not realize you responded till just now.
I am online with your guidance to stay with the basic system I have, and not an aftermarket replacement system. I will also replace ALL parts as suggested.
Question now on the evaporator (I apologize). When you say 'at least 1978', is there a year that I want more than another?
Also - I checked out my '72 Monte Carlo which I tried to convert over to R134a -it has the original condenser - so I will bet $1.00 to a donut that was why it ran very poorly.
Old Apr 11, 2007 | 11:27 PM
  #33
noonie's Avatar
noonie
78 is good for evaporator.
You won't find better
Old Apr 12, 2007 | 12:23 AM
  #34
kaiserbud's Avatar
kaiserbud
thanks
Old Apr 22, 2007 | 03:52 PM
  #35
kaiserbud's Avatar
kaiserbud
I have looked in various places for an evaporator... GMParts Direct, Ebay, etc and the prices vary. Any input on quality of teh less expensive brands. I saw some OEM on Ebay fo $200. GM was $$$$. I am thinking that might be better than the one on ACKits????
Old Apr 22, 2007 | 05:17 PM
  #36
noonie's Avatar
noonie
Nothing wrong with ackits
Old Apr 22, 2007 | 10:19 PM
  #37
kaiserbud's Avatar
kaiserbud
thanks noonie will order this week
