Tiny little distributor timing question
I'm getting ready to put the engine back in the car. I've installed a new cam, all is back together and ok.
Right now my timing marks on the dampener and scale are at TDC. MY timing dots on the crank gear and cam gear are pointed at each other. Crank dot is 12:00, cam dot is at 6:00.
For TDC with #1 cyl firing, does the cam gear need to be at 6:00 or 12:00? Thanks for your help!
John
John
If you've still got the heads off then you could check your damper's timing mark precisely using an indicator dial. If the heads are already on, you could use a piston stop to check the damper make as follows:
1) rotate crank clockwise until the piston contacts the stop. Mark a line on the damper where the timing pointer indicates.
2) rotate crank counter clockwise until the piston again contacts the stop. Make another mark on the damper where the pointer indicates.
3) Your TDC is a line exactly the distance between the two lines you've just drawn.
I had to use this method when building my current engine since the timing cover had no pointer welded on it.
I trust the dots on the gears enough to use them for rough timing. If the dots are off, I've got bigger issues with cam timing than just rough setting the dist. Honestly, really, with this almost stocker engine, I probably could have just slapped it together with out checking anything and been just as well off.
Yep, I do a 20 min. break in just as suggested.... scuff the cyl walls, get everything seated. Change the oil, flush the junk, bolts, cigar stubs outta the pan
and a fresh oil filter and oil. Heck, it's just a very, very mildly warmed up over stock 350. We're not talking 4 bolt main, O ringing the deck, $1000 heads engine. I will of course remove the carb, valve covers and dist before I re-install the engine.
A friend gave me the air cleaner. I need to get rid of it and get a decent dropped top air cleaner. Thanks for you fellers help!
John
