Harmonic balancer size
Old Mar 30, 2007 | 11:24 PM
Oldguard 7's Avatar
Oldguard 7
Default Harmonic balancer size
Today I ordered an Eagle internally balanced cast stroker crank for my 383 build. Im thinking a 8" harmonic balancer is needed. Is this statement true? If so what manufacturer balancer is recommended?
Old Mar 31, 2007 | 02:25 PM
jackson's Avatar
jackson
Nothing is absolute. Use any size you wish ... but most street chevys fare better with the larger 8". If you're building street 383 w/ cast crank ... chances are a $50 8" damper from your local discount parts house will be fine. Brand? ... what's your budget? However, someone else may post that you'll need a $300 fluidamper ... IMHO wasteful overkill in most cases.
Old Mar 31, 2007 | 06:31 PM
ratflinger's Avatar
ratflinger
NCM Grand Opening Veteran
St. Jude Donor '11, '17
Be aware that you also need a neutral balance flexplate or flywheel. Stock may have a weight welded on.
Old Apr 1, 2007 | 01:49 AM
Little Mouse's Avatar
Little Mouse
I agree that an eight inch balancer is a good choice for a street engine
especially on a stroker engine and a three hundred dollar SFI type
balancer is overkill for most people, but a $50.00 dollar balancer
would worry me. Thirty yrs ago I worked as a recieving clerk at an
automotive warehouse and we had a big machine shop on the side
of the building. The parts manufacture sold parts to us at WD
(warehouse dist. price) we sold to the jobber (parts stores) for a
twenty three percent mark up then the parts store marked it up the
most to retail price, thats three companies making a profit. You walk
into a parts store and buy a balancer for $50.00 the original manufacture
may have $10.00 dollars in the quality of the materials in the balancer.
I spend three to four times that amount on my saturday night mexican
food dinner. People spend several thousnd dollars building a 383 engine
then stick a balancer on the front that may have $10 to $15.00 spent
on materials to make it. To me this makes less sense then spending to
much for a $300.00 balancer. If I had $50.00 retail in a balancer you
would not catch my old butt standing beside the car blipping the
throttle or with the engine reved up anywhere. But hell I ran around
with a scattershield on my mostly street driven car, I like my feet
the extra weight was worth it for me.
Old Apr 1, 2007 | 08:25 AM
jackson's Avatar
jackson
All GMPP 350ci motors (including all ZZ4 & all Circle Track motors) come OE with damper # 88960604 ... 8" ... we see the 602 & 603 CT motors around here alot and rarely see a damper failure (then usually from a hard hit in nose) ... many of the CT motors can go 3 seasons without freshening. CT motors get ALOT of blipping & hard on-off throttle. Equivalent of 88960604 is a $50 parts store damper ... brands such as Dorman & Pioneer. I suppose there's lotsa guys here w/ ZZ4????? ... how many of those have failed dampers? I dunno ... but I don't recall a rash of em.
Old Apr 1, 2007 | 03:15 PM
Little Mouse
Summit must be like the warehouse I worked at just buys from
the manufacture sells it and at least that eliminates the retail
person. 18 wheeler diesels put off a lot of vibes and out of
around twenty five trucks I have had and put 750,000 to
over million miles on each one I had one balancer go bad on a
cummins, shop forman told me mack, cat. detroit,cummins all use
a fluid style balancer to control the high amplitude vibes. I started
out with mack trucks and have had all the engine brands in trucks.
I think when I buy a balancer it will be at least a one piece street
fluid balancer. At least the outer ring won't be doing any slipping.
Old Apr 1, 2007 | 04:25 PM
Scott Marzahl's Avatar
Scott Marzahl
Try GM for a 8" nodular iron damper #364709 or as Jack already said try a Pioneer. Pioneer makes a nice 8" nodular iron piece for around $80 in the Summit catalog.
As far as fluid dampers go, I can pass on what the guys that run 1/4 mile at the machine shop say and that is they only last for 1 season. Most of them run ATI's.
Old Apr 1, 2007 | 06:18 PM
Little Mouse
Guys on the forum have had fluid damper on there cars for 10 yrs
with no problem, truck engine would shake a two piece balancer
tell you would never know where the timing mark is, first thing someone
wonders with a used two piece balancer is if the timing mark has changed on them. If the gel inside a one piece truck balancer can
last for way more then a milloin miles with the heavy vibes they put
out I'm going with one of those ONE SEASON balancers.
To Harmonic balancer size
