control valve
Old Oct 14, 2001 | 11:56 AM
RUSTY79L82's Avatar
RUSTY79L82
Default control valve
why is my control vave leaking about one time a week.I go out big puddel of ps fluid.I clean it up top it off and its dosnt leak at all for about a week.
Old Oct 14, 2001 | 12:42 PM
Frankenvette's Avatar
Frankenvette
Default Re: control valve (RUSTY79L82)
This would happen to me as well. I also remember reading post on here from the past stating a similar situation. I never really knew why, so I rebuilt the entire powersteering system. Finally I have no drips.
Regards,
Jim
Old Oct 14, 2001 | 01:13 PM
rickmhsd3's Avatar
rickmhsd3
Default Re: control valve (Jim73)
A recent thread on power steering caps someone stated that the cap was supposed to breathe to relieve pressure and allow it in when necesary. Perhaps a faulty cap is allowing it to build up pressure too much and finally releasing it once a week. Just a guess
Old Oct 14, 2001 | 03:58 PM
Ben Taylor's Avatar
Ben Taylor
The most common problem with leaks is cracks in your hoses, you might want to check those out, and make sure you have grease in your valve.
Old Oct 15, 2001 | 04:01 PM
norvalwilhelm's Avatar
norvalwilhelm
If you grease the valve be sure not to use more then ONE pump. Too much grease is very bad. Big warning on new valves not to overgrease. Remember ONE PUMP
To control valve
