Proportionong valve question
Old Apr 2, 2007 | 08:18 PM
my74ls4's Avatar
my74ls4
Default Proportionong valve question
I had a leak in my proportioning valve which bled the lines dry. I removed it this moring and found the leak. Where the rear line screws into the valve there is a nut that can be removed from the valve itself. On a side of that nut there is a hole that is covered by a smallpiece of rubber. The rubber is held in place by a star washer. My star washer was missing and I had another to replace it with. What does this do? Is it a pressure relief valve or something? Would like to know what its purpose is.
Old Apr 3, 2007 | 11:01 AM
Tom454's Avatar
Tom454
Is this the one you have?
http://www.zip-products.com/Zip/prod...B0CC6072C2D8DF
Old Apr 5, 2007 | 08:44 PM
my74ls4's Avatar
my74ls4
Yes. The picture does not show the rear connection very well. I just can't figure out what the small hole is for.
Old Apr 6, 2007 | 08:17 AM
Tom454's Avatar
Tom454
A reset pin to reset the switch so the light goes off.
Old Apr 6, 2007 | 09:24 AM
Duke94's Avatar
Duke94
The rubber disc and star washer cover a vent hole for the spool valve inside the end plug. When the o'rings on the spool wear out, to avoid a hydraulic lock of the spool and resulting no proportioning function, the rubber disc blows out. What all this means is that your valve is warn out and needs to be replaced. This valve can not be rebuilt as it is pressed together.
Old Apr 7, 2007 | 10:27 AM
Tom454's Avatar
Tom454
Some of them used it as a reset.... I think it was the 70's series Pontiacs. I'll buy it though. Looks good.
Old Apr 7, 2007 | 09:54 PM
my74ls4's Avatar
my74ls4
Thanks Duke, I guess I'll get a new one on order.
To Proportionong valve question
