Really need some help!! ASAP
Old Apr 6, 2007 | 07:41 PM
nolio's Avatar
nolio
Default Really need some help!! ASAP
I know I shouldnt have posted this in the tech section but I needed some help quickly..
I am currently trying to put a pioneer headunit into my vette sun is going down and it is getting cold..
so.. I have the 2 power lines constant and acc connected to the head unit.. its grounded.. and the player turns on takes a cd but wthe sound is almost none existent / staticy.. any ideas>???
and the fm antenna is plugged in..
Old Apr 6, 2007 | 07:47 PM
rabiddawg's Avatar
rabiddawg
bad ground
out of phase speaker wires
Old Apr 6, 2007 | 09:04 PM
SIXFOOTER's Avatar
SIXFOOTER
what kind of speaker arangement? 2-2 wire speakers dorect to the head unit? Useing an amp?...
Old Apr 6, 2007 | 09:16 PM
blctalon's Avatar
blctalon
Was it like this before?
Check connections at speaker terminals.
Old Apr 6, 2007 | 11:36 PM
7T1vette's Avatar
7T1vette
Worst case.... you had the volume turned up to MAX when you fired it up and you blew out the output transistors. OR...the head unit was bad when you installed it. If you are getting ANY sound out of it, the unit is hooked up OK. Might not be any of those things; there are a myriad of possibilities.
Old Apr 7, 2007 | 01:09 AM
airck's Avatar
airck
My money is on out of phase.
Old Apr 7, 2007 | 01:42 AM
3rd_Vette's Avatar
3rd_Vette
Old Apr 7, 2007 | 02:08 AM
another-user's Avatar
another-user
never heard of out of phase speakers. what is it? mixing up the positive and negative wires on the speaker?
Old Apr 7, 2007 | 02:26 AM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
yes...so one speaker goes out while the other speaker goes in....
i think you have a "bridge" missing or not connected
Old Apr 7, 2007 | 08:21 AM
nolio's Avatar
nolio
man it was a LONG night..
I wanted this stereo hooked up because I am going to mrytle beach today after work to meet up with the wife and friends (already there)..
Anyways after I posted this issue with the speaker I went back outside to kick the head unit around.. on the way out I grabbed the instructions. Turns out I had the positive of the left right speaker attached to the negative of the back left speaker.. (i know.. I know..)
I worked on the amp and sub until midnight last night.. thiswas my first stereo... hopefully I have everything taped up good enough that she won't catch fire on the way down..
thank you for the suggestions everyone!!
Old Apr 7, 2007 | 08:22 AM
corvette_maniac's Avatar
corvette_maniac
We need more info, such as the model of that Pioneer. If it's an older one that has the rotary volume **** (potentiometer) then it could be dirty with oxide buildup causing the symptoms you describe. Speakers that are wired 180* out of phase don't cause static. However, you will loose low end as one speaker is sucking in while the other is pushing out.
Start by eliminating components. Try connecting one speaker at a time on different channels. Try different sources....such as CD, cassette, radio.
To Really need some help!! ASAP
