Kill Switch?
Old Oct 15, 2001 | 02:31 PM
Bifkin's Avatar
Bifkin
Default Kill Switch?
I know its usually not a good idea to broadcast this, but where does everyone have your ignition kill switch mounted?
I just got a steering column with a cruise control lever/button, and i don't have CC... so i thought that button would be good, but my mechanic tells me its not a good enough switch for that to work.. and we'd have to take the column apart to put one in... and considering we JUST put that column in... neither of us are too eager to take it back out...
Is this accurate? or is there an easy way to wire it in to make a seamless kill switch? otherwise, where do you have yours mounted? pics?
Thanks.
Old Oct 15, 2001 | 02:43 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
Default Re: Kill Switch? (Bifkin)
Mines on a remote control connected to a Sears Security battery. :D
Old Oct 15, 2001 | 03:23 PM
Scooter70's Avatar
Scooter70
I knew someone who had it connected to the cigarette lighter. Push the lighter in, go. Pull it out, no go. Just have to make it so the lighter doesn't operate as usual. Might be annoying if it kept popping up every minute or so... :crazy: I like this idea since it's something nobody'd ever think to check. However this won't do if you want to use the socket to power anything (radar detector, G-tech Pro, etc)
Matt
1970 Corvette coupe
Old Oct 15, 2001 | 03:33 PM
BSeery's Avatar
BSeery
From: Exiled to Richmond, VA - Finally sold my house in Murfreesboro, TN ?? Corner of "Bumf*&k and 'You've got a purdy mouth'."
CI 6-7-8 Veteran
CI-VIII Burnout Champ
St. Jude Donor '06-'10, '13
Your mechanic was right. The wiring to the CC button is way too frail and to thin of a wire to handle that kind of voltage.
Old Oct 15, 2001 | 04:14 PM
Bifkin's Avatar
Bifkin
Default Re: Kill Switch? (BSeery)
Yeah, those were his exact words... just about.
What can you use that will look seamless? The lighter sounds good, but then i won't be able to swap my radar detector in & out of the car.
He said he'd find a place for a switch thats easy to reach, but hidden... I hate leaving things up to people though...
hey, is there anything I CAN do with that stupid CC button? (and no, i'm not installing CC)
To Kill Switch?
