another timing question
Old Apr 7, 2007 | 12:36 PM
jack 69's Avatar
jack 69
Default another timing question
is the rule, 36 deg + 16 deg apply to BB like SB?.. pump gas is 91 CA.... cam is close to the 435hp cam but hyd.. L36 intake with some porting and matching of intake and exhaust.... edelbrock #1910, 850 cfm spread bore... 10:1.... the car runs nice but when i hammer it,... it just does not come on like i think it should.... expecting to much out of 38 year old car?
Old Apr 7, 2007 | 01:16 PM
zwede's Avatar
zwede
Big-blocks like about the same timing as smal blocks. Some big-blocks prefer 38 dgr due to crappy chambers.
I prefer to keep total timing below 50 degrees though. Might want to switch over to a 10 or 12 dgr vacuum can.
Old Apr 7, 2007 | 02:49 PM
jack 69's Avatar
jack 69
i did pull the timing back to 50 deg and i like the way it runs and sounds.... don't know to much about the chambers but the head casting #3917215, is what i have noted in one of my books... the vacuum can i have is B-26,.. 16@11-13hg ... 16 @ the crank.... i have very good vacuum at idle,14hg and 23hg at cruz... thinking maybe i should try the B-1 vacuum can, it's all in at 16-18hg.....
THANKS!
Mike
To another timing question
