76 TH350 shift cable kinking
Old Apr 10, 2007 | 11:45 AM
GlockGuy's Avatar
GlockGuy
Default 76 TH350 shift cable kinking
My car has been sitting since 1999 and finally getting it going. Last night could not get the key out and found that the shift cable is kinking and binding. It was pretty cruddy, cleaned and lubed but still kinks when shifting. The cable has a permanent bend/kink at the shifter end. Is this a common problem due to dirt/age etc? I found the cable at Zip (ST-335) for $84.50 is this the best deal? At GM pars direct I can not select a year model older than 1980. I appreciate the help. I have the car running and almost ready to hit the road.
Don
Old Apr 10, 2007 | 12:57 PM
vettebak's Avatar
vettebak
i had this problem also i had park the car and coulden get the key out
I was lucky parkt right in front of a garage
I had to taked the kabel out lubed it and turned it around
so i mean the side that was on the transmision is now on the stearing kollum
and this is still doing it job right
I have to replace it bud still if it works don't replace it
right lol
Old Apr 10, 2007 | 02:47 PM
GlockGuy's Avatar
GlockGuy
right lol
Thanks Vettebak,
I lubed the cable but it did not help so I guess Ill have to thow more money at the car to get it back on the road. Seems like it is one thing after another.
Old Apr 10, 2007 | 03:31 PM
SIXFOOTER's Avatar
SIXFOOTER
Where did you find one for $85? I just need a new boot for mine and the best I could find was $149 for a whole cable
Old Apr 10, 2007 | 03:52 PM
GlockGuy's Avatar
GlockGuy
Hi, I found it on the Zip websight.
ST-335 69-77 auto shift cable $84.50
ST-337 69-77 column interlock cable $40.00, which is what I ordered.
If you need the boot off of the interlock cable I could try to get my old one off w/o damaging it and you could have it.
To 76 TH350 shift cable kinking
