Interesting Electrical Problem
Old Apr 10, 2007 | 02:22 PM
DIPPOLD's Avatar
DIPPOLD
Default Interesting Electrical Problem
I am at my end in trying to figure it out. I have a 71 with Air, and if I leave the plug in the AC compressor in various points on the fan switch I cannot turn off the engine. If I pull the plug then the ignition switch acts normally. I have checked each one of the electical connects to make sure they are connected to the right thing and the right way. I think it must be one of the relays. The cost of replacing the relays or switchs is not high but I just don't want to replace stuff just for replacing them. Help would be appreciated.
Old Apr 10, 2007 | 02:54 PM
SIXFOOTER's Avatar
SIXFOOTER
So, you have everything hooked up normal, start it up and then turn off the key and it keeps running. Disconnect the AC Comp connector and it dies?
Old Apr 10, 2007 | 06:45 PM
7T1vette's Avatar
7T1vette
Interesting. There is a relay on the left side of the engine bay firewall which has something to do with activating the compressor clutch for 3seconds after switching off the engine. The extra load on the engine was supposed to help prevent "engine dieseling" [engine run-on]. Maybe there is some failure mode within that device that is allowing power to continue flowing to the ignition. These relays were only on C3's for 2 years, I believe; so there is little information on them. You can't buy aftermarket replacements, but you might be able to find one in a Corvette salvage yard, if that is your problem.
Old Apr 10, 2007 | 09:24 PM
Big2Bird's Avatar
Big2Bird
Wow
You get problem of the year.
Wish I had a 71 schematic.
Old Apr 12, 2007 | 09:06 AM
DIPPOLD's Avatar
DIPPOLD
Sixfooter you have it right. The maint book doesn't show you how to diagnoise the relay on the firewall nor the anti-dieseling switch in the dash. I guess all I am left with us replacing the relays. Thanks guys for her help. I will let you know what I find.
Old Apr 12, 2007 | 10:58 AM
tracdogg2's Avatar
tracdogg2
Unplug the hi blow relay on the engine side of the evap case. If it shorts inside it will feed power back to the ignition switch.
Mike
Old Apr 12, 2007 | 11:28 AM
7T1vette's Avatar
7T1vette
Super tip, Mike! Never heard that one....good to know. Thx.
Old Apr 17, 2007 | 05:33 AM
DIPPOLD's Avatar
DIPPOLD
Thanks Mike, I will give it a try and let everyone know the outcome.
Old May 2, 2007 | 03:24 PM
DIPPOLD's Avatar
DIPPOLD
So still can't figure this thing out, I replaced the relay on the Evaporatory and same problem. Strange I only have 1 relay on the inside of the car which is mounted on the heater/cooler box, the maint book and the build book show two relays. Did some further testing and found if I have everything hooked up and I turn the control to the ACX setting the car will not turn off, if I have the control on the heat setting then I need to have the fan switch on the first position if it is in the off position the car will not turn off. Yes, I checked the fan switch to make sure the replacement is the right one for cars with AC. This may mean a trip to the repair shop. Some how it is supplying voltage to the coil that is why things won't turn off. Any further suggestions?
Old May 2, 2007 | 05:46 PM
DeeVeeEight's Avatar
DeeVeeEight
Default another long shot
This is another long shot, but who knows?
Has the dash and/or center console been removed and or replaced? There may be a Hot/Ground wire pinched together that is sending voltage back through the ground circuit, just enough to keep the coil alive.
What was the history of events before this problem started? Did you have anything apart, replaced, take the car to the shop, etc... ?
Old May 2, 2007 | 08:55 PM
Big2Bird's Avatar
Big2Bird
Call me crazy, but maybe the ignition switch is bad.
To Interesting Electrical Problem
