rad shroud
Old Apr 14, 2007 | 10:36 PM
babylonvette's Avatar
babylonvette
Default rad shroud
i am putting in the a/c condenser on the front of the shroud and do not know if it bolts directly to rad support ,or are there small rubber bushings at the lower bolts, i looked in the assembly manual and it looks to bolt direct, not sure as i didnt take it apart just trying to put it back together, thanks for the help
Old Apr 14, 2007 | 11:12 PM
tobyte1's Avatar
tobyte1
Don't know about other years, but on the '75 there are rubber bushings with steel sleeves on both the top and the bottom.
Old Apr 15, 2007 | 10:56 AM
schmegeggie's Avatar
schmegeggie
There were no rubber bushings in my 69, just bolted directly to the support.
To rad shroud
