front tires rubbing
Old Apr 19, 2007 | 10:03 AM
chuck d's Avatar
chuck d
The handling differances you noticed might have something to do with the current alignment of your front end. My car did the same thing.
Old Apr 19, 2007 | 11:26 AM
7Deuce's Avatar
7Deuce
I found the following website helpful when comparing tire sizes...
http://www.miata.net/garage/tirecalcold.html
Old Apr 19, 2007 | 11:28 AM
CaptainHook's Avatar
CaptainHook
Originally Posted by TortureTest
Jetdoc, if you pull to one side hard, combined with poor behavior with rubbing, you owe it to yourself to check that control arm....trust me on that. I narrowly escaped a disasterous situation and I suspect my family is pretty happy I did.simply jack one side up and inspect. a crack will mean that you flex, when you flex you rub at best, at worst.....it gives at the wrong time.
I disagree with some peeps here on the rubbing with that tire size. It isnt o.k. and its not something you should just live with, period.
Besides being both annoying and disconcerning, its also going to be stupid dangerous as you will have to monitor wear, which is almost impossible.
going 50 on a hairpin and losing your tire could kill you......proper tires likely wont.
Cheers to all and no offence, were allowed to disagree.
My car doesn't pull one one side when braking and the rub is on both sides but I'll have to get under the car this weekend and see if I have a more pressing problem. Better be safe than sorry.
Originally Posted by sxr6
One other thing I did notice, my 69 with 255x60 BFGs on the front would follow road irregularities, after I switched to 235x60s that problem went away!! Maybe it was because the diff brand wasn't so flat across the surface, I don't know but it sure handles a LOT better.
I have the same problem. I think I'll get the narrower tire.
Old Apr 19, 2007 | 12:20 PM
rexx78's Avatar
rexx78
My 78 rubs on the drivers side, it has the stock tire size 255 60-15.
Old Apr 19, 2007 | 12:58 PM
Brooklinite's Avatar
Brooklinite
now have an extra set of 255s for the rear in case they wear out faster than the front
What on earth would cause that?
Old Apr 19, 2007 | 03:20 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
My 77 doesn't rub on the frame or fenders.
Old Apr 19, 2007 | 06:12 PM
enkeivette's Avatar
enkeivette
Mine rub too, so what. Just laugh at how polished the frame will get. From the rust on yours I can tell that you don't drive it often. And if it rubs on the inner fender, bust out the hack saw and cut the corner off.
Old Apr 19, 2007 | 10:55 PM
CaptainHook
I don't see how a rusty frame equates to how often a person drives their car. If I had a shiny frame, that would be a fair assumption. I haven't own the car that long so working on the frame is not that high on the list right now. Hopefully in a few years my frame will look as nice as some of cars here.
As far as rubbing the frame and cutting the fender, I think would rather get a narrow tire. Leaving the tire rub the frame or cutting the fender feels like the act of bubba.
Old Apr 20, 2007 | 08:07 AM
jetdoc's Avatar
jetdoc
Word...thats what I was thinking, WTF is he talking about?
Old Apr 22, 2007 | 10:20 AM
xCCTer's Avatar
xCCTer
CF JASOC Member
From: Downtown Annapolis, MD. The Future is where we all have to live. Let's not screw it up.
Originally Posted by 7T1vette
I think that 235's are the largest that should go on the front end of a '71.
http://www.planethoustonamx.com/main...sion_chart.htm
Here's a quick conversion chart from old numbers to new that may be of help.
I've never seen a pre-72 shark with wider than G70 series (225/70R15?). As far as I know they came with F70-15s (215/70R15?).
I'm still using the Firestone Wide Ovals, so no need for conversion. Still F70-15s. I love 'em!
Old Apr 22, 2007 | 03:19 PM
kaiserbud's Avatar
kaiserbud
...going 50 on a hairpin and losing your tire could kill you......proper tires likely wont. Cheers to all and no offence, were allowed to disagree.
If you are going 50mph into a hairpin and you have the steering locked 100% left or right, chances are you are eating it anyway
The excessive rubbing, of course would cause tire failure, but someone would have to be slamming sterring side to side for that to occur. I know I don't do that - a driver doesn't need to do that - even in ferocious driving. The rubbing is simply from pulling in the driveway, parking, etc...
Old Apr 22, 2007 | 11:31 PM
CaptainHook
Thanks.
Old Apr 23, 2007 | 11:08 PM
  #33
kaiserbud's Avatar
kaiserbud
exccter - thanks for the chart
Old Apr 24, 2007 | 01:54 AM
  #34
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Well then Bubba's name is GM. When they started offering the 255 tire, they trimmed the inside lip of the fenders. It's not noticeable from anywhere except inside the wheel well.
Old Apr 24, 2007 | 09:25 AM
  #35
Belgian1979vette's Avatar
Belgian1979vette
I have the same tire size and they rub to. You can weld a little on the tabs of the lower control arm. They control how much the tire can turn in, but that is about it.
Old Apr 25, 2007 | 07:30 PM
  #36
CaptainHook
I'll call GM Bubba from now on.
I didn't find any cracks with my lower control arm so I ordered a set of 225/55-17. Hopefully, they'll clear the frame as well as the fender.
Old Jul 22, 2007 | 11:32 PM
  #37
jcswm's Avatar
jcswm
Originally Posted by ajkogut
Mine also rub on the frame. I never really gave it much thought, I just don't **** the wheel that far... Too many other issues to worry about
100%
Full lock turns are hard on the Ball Joints too!!
