front tires rubbing
Old Apr 18, 2007 | 12:28 AM
CaptainHook's Avatar
CaptainHook
Default front tires rubbing
I currently have 255/60-15 tire. I just noticed the back of my front tires is rubbing the car as shown in the picture. From what I read, most people are rubbing on the fender lip. Is there a problem with my steering moving too far or is it just the wrong size tire? Thanks.
Old Apr 18, 2007 | 12:40 AM
TortureTest's Avatar
TortureTest
Tire size is fine...check and make sure your lower control arm is not cracked. I had that issue and was I ever glad I found the problem.
Tell tale sign is if it pulls to one side more than usual or especially when under the influence of braking.
Good luck.
Old Apr 18, 2007 | 10:00 AM
dgruenke's Avatar
dgruenke
Wrong tire size. The 255/60R15 was an optional tire on later C3's and even then the factory trimmed the wheel wells. Some earlier C3's are fine, and some are not. It is on a vette by vette basis.
I must admit, though, I have never really seen it rub on the frame.
Old Apr 18, 2007 | 10:08 AM
sxr6's Avatar
sxr6
255s fronts rubbed the frame on my 69, 235s work & look real good with 255 rears
+ now have an extra set of 255s for the rear in case they wear out faster than the front
Old Apr 18, 2007 | 11:51 AM
ajkogut's Avatar
ajkogut
Mine also rub on the frame. I never really gave it much thought, I just don't **** the wheel that far... Too many other issues to worry about
Old Apr 18, 2007 | 02:12 PM
CaptainHook
I will check the lower control arm to make sure that's ok. If it is the tire, I'm guessing 225/55-17 will be ok. That's as close to the stock 215/70-15 size that I can find. Will this tire size fit my new 17x8 rim? How will 225/55-17 look? Anybody has any picture of it? Thanks.
Old Apr 18, 2007 | 04:39 PM
7T1vette's Avatar
7T1vette
I think that 235's are the largest that should go on the front end of a '71. Others will disagree, but 245's and up will likely rub. I don't throw my car into .9 G turns, so I don't need the larger front tires. Actually, I have 225's on the front and 235's on the back. I think I will go 235's all around, when I replace them next time.
Old Apr 18, 2007 | 04:48 PM
jetdoc's Avatar
jetdoc
Good luck.
Not trying to hijack but the rub mark is exactly what I have on my left side, on my 73, and it pulls to the left, especially when braking.
Is it possible to have worn control arm on that side, as opposed to a cracked one?
Old Apr 18, 2007 | 08:27 PM
WESCH's Avatar
WESCH
Hi
Very normal rub mark with this tire.
You can see it also rubs the fire wall lower skirt when the car lifts off or the wheel drops into a ditch during steering. The tire is just too wide for this model.
You can continue like this as it only happens during full steering and this is only done when parking the car or maneuvering it at very slow speeds.
235 front is fine.
Günther
Old Apr 18, 2007 | 09:14 PM
Chas D's Avatar
Chas D
2nd Gear
I Have 255x60-15 Comp TA's on my 73 and they rub just a little at full lock. There is no rub on the rears at all.
Old Apr 18, 2007 | 09:15 PM
kaiserbud's Avatar
kaiserbud
Originally Posted by dgruenke
Wrong tire size.
I agree. Mine does the same - seen it a bunch... but I don't know if any 255 was ever offered as optional on a C3 - I don't think they even had that tire size ratings back then.
Also - each vette is glued up differently. I do not know what the tolerances were - but the skirt could vary quite a bit - and compound the rubbing at the back of the tire.
CmbtApl's Avatar
CmbtApl
I have Goodyear Eagle ST 245/60/15's on my 69 convertible and have a slight amount of frame rub on both front wheels where the rear of the tire touches the frame. See pics.
However, there doesn't seem to be any problems with the edge of the tires.
[IMG][/IMG]
Old Apr 18, 2007 | 09:17 PM
kaiserbud's Avatar
kaiserbud
Wrong tire size.
Old Apr 18, 2007 | 09:42 PM
Sayfoo's Avatar
Sayfoo
In my simular case, the 255's onlly rub when the steering is full over, as in parking. One of these days, I will extend the steering stops to overcome this. In the mean time, I don't think this is a problem, as there is nothing sharp to hurt the tires. I DO try not to crank the steering farther than 90%, so it doesn't rub.
Old Apr 19, 2007 | 12:24 AM
CaptainHook
So would you guys recommend 255/50-17 or 225/55-17? Thanks.
Old Apr 19, 2007 | 12:29 AM
TortureTest
Jetdoc, if you pull to one side hard, combined with poor behavior with rubbing, you owe it to yourself to check that control arm....trust me on that. I narrowly escaped a disasterous situation and I suspect my family is pretty happy I did.simply jack one side up and inspect. a crack will mean that you flex, when you flex you rub at best, at worst.....it gives at the wrong time.
I disagree with some peeps here on the rubbing with that tire size. It isnt o.k. and its not something you should just live with, period.
Besides being both annoying and disconcerning, its also going to be stupid dangerous as you will have to monitor wear, which is almost impossible.
going 50 on a hairpin and losing your tire could kill you......proper tires likely wont.
Cheers to all and no offence, were allowed to disagree.
Old Apr 19, 2007 | 06:34 AM
Bluey's Avatar
Bluey
I had the exact same problem on my 73 a few weeks ago. On my lower control arm there is a small plate with a knuckle on it. When I have the wheel on full lock it is supposed to make contact with the flat on the steering knuckle, therefore stopping the tyre from rubbing on the inner frame.
The metal on mine had worn and the wheel was hitting the frame before the knuckle was hitting the stop. We used a mig and built up the plate on the control arm. Eliminated the problem.
Maybe that is your solution?
To front tires rubbing
Old Apr 19, 2007 | 07:38 AM
Gordonm's Avatar
Gordonm
The 255 50 17s rubbed on my 72. I am running 255 45 17s up front now with no rubbing.
I tried years ago 255 60 15s and they rubbed. I ran 245 60 15s with no problems.
Old Apr 19, 2007 | 08:02 AM
jetdoc's Avatar
jetdoc
Torture Test, thanks for the advise. Will check it out this weekend.
Old Apr 19, 2007 | 08:53 AM
sxr6's Avatar
sxr6
One other thing I did notice, my 69 with 255x60 BFGs on the front would follow road irregularities, after I switched to 235x60s that problem went away!! Maybe it was because the diff brand wasn't so flat across the surface, I don't know but it sure handles a LOT better.
