Weird electrical problem?
Old Apr 18, 2007 | 09:51 AM
rudolph schenker's Avatar
rudolph schenker
Default Weird electrical problem?
Why would my voltmeter on the gauge cluster read normal (12-14) while the engine is running, then when I turn the head lights on go to zero? The alternator is new, the lights don't dim when turned on. Am I missing something obvious? Electrical issues are not my strong suit. Any help would be appreciated!
Old Apr 18, 2007 | 10:24 AM
SIXFOOTER's Avatar
SIXFOOTER
you have a ground problem in the dash
Old Apr 18, 2007 | 02:34 PM
rudolph schenker
I'll start looking. Thank you!
Old Apr 18, 2007 | 08:21 PM
croaker's Avatar
croaker
Mine does the same I found where my alternator plugs the wire was almost broken in two fixed that it got a lot better. Does it stay low or does it come up after a while?
Old Apr 19, 2007 | 02:19 AM
rudolph schenker
So far my connections 'look' intact. I'll keep checking.
To Weird electrical problem?
