71 tank question
Old Apr 18, 2007 | 11:39 PM
bondoboy's Avatar
bondoboy
Default 71 tank question
I had some trouble awhile back with water getting in the gas tank. I installed a new cap and cleaned out the drain hose. I found more water in it yesterday. What else could be the problem? Who makes the nicest American made gas tank? I would like to drop the tank to see if the build sheet is there anyway. Thanks a lot.
Marty
Old Apr 19, 2007 | 12:16 AM
7T1vette's Avatar
7T1vette
Two things that I can think of.... 1) your gas cap is not a sealed cap and rain/wash water found a way to get in under it; 2) there's a collection of water in the gas supply tank at the station where you are buying your gas. Next time you fill up, take a quart jar with you and fill it first--then your tank. Let it settle and see if any water collects at the bottom of the jar. If so, show the manager; then have him give you some FREE bottles of HEET (basically alcohol which will mix the water in with the gas and cycle it through the engine with no problem) to clear the water from your tank. If neither of those...I don't get the "gold star".
Old Apr 19, 2007 | 12:32 AM
bondoboy's Avatar
bondoboy
I have a new, non-vented GM cap on it. After I got the water out last time, it was fine. The car sat a little while due to cold weather and a bad battery. I put in a new battery and started it. It ran until the front bowl filled with water. I'm baffled.
Old Apr 19, 2007 | 12:04 PM
7T1vette's Avatar
7T1vette
I believe that it is water in the gasoline you are buying. Is the station an "old" facility? (Newer stations put water "traps" on their equipment.)
Old Apr 19, 2007 | 02:37 PM
bondoboy's Avatar
bondoboy
The stations around here are all newer.
Old Apr 21, 2007 | 01:07 AM
bondoboy's Avatar
bondoboy
Thanks for the help.
Old Apr 21, 2007 | 08:40 AM
TimAT's Avatar
TimAT
If the tank is rusty on top then you need a tank. Does the water seem to get there after it rains or you wash the car? Do you see any puddles of water under the filler door? Are you leaving it with the tank full or empty? Temperature changes could cause condensation in the tank.
The boot around the cap could be holding water and dumping it into the tank. The sending unit could be leaking too, but I'd think the amount of waer that could get in that way would be miniscule.
Old Apr 22, 2007 | 09:53 AM
xCCTer's Avatar
xCCTer
CF JASOC Member
From: Downtown Annapolis, MD. The Future is where we all have to live. Let's not screw it up.
Nice car!
Old Apr 22, 2007 | 09:54 AM
Pat71vette's Avatar
Pat71vette
Default water
I found the same problem it turned out to be the gasket between the filler fitting and the gas tank easy fix
Old Apr 22, 2007 | 10:35 AM
GaryS's Avatar
GaryS
Quanta Products at
http://www.quantaproducts.com/products.asp?dept=260
makes the repro tanks using original tooling.
Old Apr 22, 2007 | 11:55 AM
Crunch-o-Matic's Avatar
Crunch-o-Matic
A few things it could be:
1. The cap (no seal/bad seal)
2. Bad gas from the filling station
3. A hole somewhere in the tank
4. The car has sat all winter/or sits mostly and condensation has built up.
At a minumum I would drain the the tank. All you have to do is get a mower can and disconnect the hose on the bottom of the tank and be ready...
Refill the tank and add a fuel system treatment. I had to replace the gasket on my cap and no more problems.
If that doesnt fix it, tanks are relatively cheap and arent hard to install. You can spend a bunch of nice sunny days trouble shooting that old tank...marginal benefit analysis says the best thing to do is replace the 30+yr old tank in one afternoon and enjoy the sunny days!
Cheers,
Crunch
Old Apr 22, 2007 | 11:15 PM
bondoboy's Avatar
bondoboy
I appreciate all the help, guys. I siphoned the tank today and 1 to
1 1/2 gallons of water came out. That's too much to be condensation. I will drop the tank and check for holes and make sure the gasket is OK. I would like to see if the build sheet is there anyway. I believe the water is from the rain. Like I said, I cleaned out the drain hose and put on a new cap. I don't believe it's from the gas station, because I fill my truck at the same stations and never have trouble. Again, thanks a lot for the help.
Old Apr 24, 2007 | 06:15 AM
tomcat65's Avatar
tomcat65
I dropped my tank because of probs with water and rust,
I found it had no gasket between fillerneck and tank at all , seems like they forgot it from the factory !!!!!
,,open door for rain water basically
Old Apr 24, 2007 | 08:39 AM
shoptek's Avatar
shoptek
The tank is easy to remove...Just be careful of the fuel/vapor seperator and
the rubber hoses mounted to it. it is mounted on the upper left side of the tank. I almost broke mine when I removed the tank on my '71.
Old Apr 24, 2007 | 02:41 PM
bondoboy's Avatar
bondoboy
Thanks again for the help. I will drop the tank when I get some time.
To 71 tank question
