Engine Rebuild
Old Apr 24, 2007 | 06:25 PM
  #41
JustinD's Avatar
JustinD
About the 224/224 @ .50 cam. Should I go steeper than this? I calculated the cr to be about 9.1 to 1.
Old Apr 24, 2007 | 08:08 PM
  #42
Little Mouse's Avatar
Little Mouse
Don't go any further up in duration if you expect to have any lower
end torque with a 350.
Old Apr 24, 2007 | 08:11 PM
  #43
JustinD's Avatar
JustinD
That is what i figured.
Old Apr 24, 2007 | 08:40 PM
  #44
jord2720's Avatar
jord2720
Default JustinD rebuild ....
jord2720
Justin just got finished with my L48 rebuild. Just wondered were you were on your project. Last entry I saw was 2005, so you may have finished by now. I went with the L31 vortec Iron heads and it turned out way better than my expections. At a comfortable price I might add!!!!! Ground up took best part of 2 weeks, and that's including machine shop Parts ordering time. Mine is/was a stock 80 L48/auto.
If ya want 400 +HP, and still use a cam that talks, and still use you stock convertor let me on here if your interested.
Old Apr 24, 2007 | 09:24 PM
  #45
jord2720's Avatar
jord2720
cs xe268h-10.... I.224 X 230 @50 ..gross valve lift I. 477/X .480 ...LS 110 works great with automatic no stall convertor. Flat tops 2 reliefs. 64 cc chamber stock L31 Iron vortec heads on the gen 1 block. ...355 gear complete spec's at summit.
Old Apr 26, 2007 | 08:14 PM
  #46
jord2720's Avatar
jord2720
So If I went with a set of these:
http://cgi.ebay.com/ebaymotors/Seale...spagenameZWDVW
Had my cylinders bored .30 over to fit them and got a rebuild kit for another 100. And a new cam. Then I would be good to go. About how much is it to have the cylinders bored?
I'm in north GA. Last I bored was 10$ a hole, but thats been awhile. I checked out your piston and that will get the job done , but if its not to late I would consider the same in a Hypereutectic piston....Price is no were near the price of forged pistons.
Check out this site for additional info on there pistons. Federal Mogul ....good stuff at a fair price. Check out this site additional info.http://<u>http://www.federal-mogul.c...reutectic/</u>Piston & ring set 215$ at summit. Link below tells ya all about them. Just thought you might want to check it out?? There there ones I bought, but standard bore.
http://store.summitracing.com/egnsea...+115&x=48&y=18
later,
jord
Old Apr 29, 2007 | 06:56 AM
  #47
jord2720's Avatar
jord2720
Know your Corvette spec's ?
http://www.corvetteactioncenter.com/...0/80specs.html
Old Apr 29, 2007 | 11:31 AM
  #48
JustinD's Avatar
JustinD
I actually got a cheap set of new flat tops with the pins. They are federal mogul. The machine shop that I went to had them extra because a guy didn't end up using them he needed dished, so they cut me a deal on them 80 bucks for all 8 with the labor of installing the rods.
