c3 cold air intake questions
Old Apr 24, 2007 | 11:42 PM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
Originally Posted by flynhi
Correct on both counts. I did have the hood unlatched and open a bit and I should have said positive pressure. I was puzzled by this since GM and others clearly had different results.
Regardless, I prefer my method since it looks OE with a flat hood at the cowl.
Thanks. Was hoping you didn't take that wrong. It's probably just one of those difficult to duplicate tests where "your results may vary".
I've had both front grill and cowl fed inductions. Each work, but I do like that L88 bulge...
Old Apr 25, 2007 | 12:50 AM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
Originally Posted by batsmith
....I can't believe that I am the only one interested in getting cold air to a carb with a modern look, especially considering how hot the engine compartments are on old vettes. I guess I 'll fab the whole thing myself....
i am right behind you on this one keep me posted on what you are doing......
Old Apr 25, 2007 | 01:00 AM
saudivette's Avatar
saudivette
Originally Posted by jpatrick636
How about something like this?
Good pic, I had a mental picture of making something like this for when I fit a hood scoop
Old Apr 25, 2007 | 02:12 AM
SEVNT6's Avatar
SEVNT6
When my Vette was maybe a couple of years old I thought I'd put an open early style chrome air filter on it. It was in the fall & the air was cool and man it sure did sound nice when I opened her up but it didn't feel as quick at speed.....
A week or two later I put it back to stock.....
Old Apr 26, 2007 | 02:48 PM
batsmith's Avatar
batsmith
These fed two flex hoses that connected to a closed round air filter OE box on my carb. This looked more symmetrical and worked well enough.
When I converted to the 383 TPI, I needed a slightly higher hood to clear the tpi plenum so I installed a BB hood. This gave me more clearance over the radiator frame so I fabbed a larger scoop that attaches to the radiator frame, feeds the air filter at the front of the throttle body and seals to the underside of the hood as it closes.
I was leaning towards the same thing you set up when you bought the larger hood, then running that into two hoses, then to the carb. I really want the carb piece to be small and out of the way so that the carb is exposed and there is plenty of room to work without having to remove the breather. I have already started doing mach ups for the two main pieces.
Do you have any pictures of your set-up that could could post?
Old Apr 26, 2007 | 02:52 PM
batsmith's Avatar
batsmith
Thanks, I will try to post some pics when I get things going, I will also try to make it easy to duplicate if I can.
Sevnt6
your car sure makes a case for stock, very, VERY nice!!!
Old Apr 26, 2007 | 04:13 PM
SEVNT6's Avatar
SEVNT6
Sevnt6
Thanks man...........It's to old & original to mess with now so I went with the bling....
Now if that old L-48 ever blows up...................
