*#%^Crossfire Question
Old Apr 24, 2007 | 08:48 AM
69/03vette's Avatar
69/03vette
Default *#%^Crossfire Question
Can anyone tell me which cylinders are tied to which throttle bodies on an 82 crossfire injection system?
Old Apr 24, 2007 | 09:02 AM
big_G's Avatar
big_G
It is a shared, common plenum.
Old Apr 24, 2007 | 09:40 AM
69/03vette's Avatar
69/03vette
Thanks Big_G
The reason I asked is the engine won't start. We're getting spark to all cylinders. Cylinders 3,4,7 & 8 are getting fludded with fuel and 1,2,5 & 6 look dry according to the spark plugs. I thought maybe if each throttle body was tied to particular cylinders we would be able to determine which one of the throttle bodies was bad (if the probblem is with the throttle bodies), since there seems to be a pattern as to which cylinders are getting fludded. Do you have any suggestions for this type of problem?
Old Apr 24, 2007 | 09:56 AM
big_G's Avatar
big_G
My guess is either the fuel is contaminated or the timing is off. Air+fuel+spark = Boom! Spray some carburetor cleaner in the throttle body and try again.
Old Apr 24, 2007 | 11:54 AM
hugie82's Avatar
hugie82
Default they favor some cyl.
If the front tb is leaking you wil see 1,3 pretty wet for example.
Old Apr 24, 2007 | 04:07 PM
Toms82's Avatar
Toms82
Hi,
From what I have read, the right throttle body feeds the left cylinder head and the left feeds the right. I think that's where the crossfire name came from.
Good luck,
Tom
Old Apr 24, 2007 | 04:37 PM
big_G's Avatar
big_G
Well, sort of. The runners are under the t/b top plate, but they are in an open plenum.
To *#%^Crossfire Question
