replacing valve springs with heads on engine
edit...didn't see scott and lars' posts . . .
260# seat?????? depending on the valve weight you really only need @200 pound seated and @480 open for sub 7500 rpm solid roller cams of under .700 lift to prevent valve float.
A Chevy 2.02" valve has a surface area of 3.2 square inches. If you put 20 pounds of pressure in the cylinder, you have a total force of 64 pounds holding the valve in place. Since the only force on the valve during spring removal is whatever sideload you get into the spring compressor, the 64-pound force is more than enough to hold the valve during spring removal.
At the same time, the 20 pound pressure is applying a total force of 251 pounds to the 12.56 square-inch piston at TDC. With the piston right at TDC, the engine won't turn over with this force on the piston.
If you put 100 pounds of pressure in the cylinder, this will put a total force of 320 pounds against the valve - way more than needed. But more importantly, it will put a total force of 1,256 pounds against the top of the piston at TDC. If that piston is not exactly at TDC, you stand a really good chance of the engine suddenly turning over when you least want it to. I've had it happen, and you have to go change your pants afterwards.
Ok I get the idea, you guys are right, the spring pressure is not on the valve. I forgot about that. Thanks for all the good info.Anyone can recommend a good valve spring compressor ?
