1982 VSS problems
Old Apr 30, 2007 | 09:10 PM
thetazmanjim's Avatar
thetazmanjim
Yes it's TBI
Old Apr 30, 2007 | 09:24 PM
thetazmanjim
The latest symptom is when touching the accelerator slightly the car acts like it is flooding out like a dead spot in an accelerator pump (if it had a carburetor). When driving at approximately 45 MPH and touching the gas pedal slighlty it does the same. When driving normally the trans acts like it's taking too long to get into overdrive which I dismissed as maybe another problem in the making or a typical 700R4 like the one I had in an '88 Camaro years ago. I'm getting fonder of this corvette as we are getting closer. Thanks everyone.
Old Apr 30, 2007 | 10:12 PM
vetteaddic's Avatar
vetteaddic
The vss is on the trans ,don't know if your has a speedo cable,if it does ,the vss is connected to the cable and trans tail .
Old May 1, 2007 | 07:23 AM
jdp6000's Avatar
jdp6000
Those symptoms are identical to the ones I had when my fuel pump went. A clogged fuel filter could also cause that. Check your fuel pressure.
Jim
Old May 1, 2007 | 07:50 AM
jdp6000's Avatar
jdp6000
Old May 1, 2007 | 11:00 AM
FASTAZU's Avatar
FASTAZU
2018 C4 of Year Finalist
2015 C4 of the Year Finalist
St. Jude Donor '16
Back of speedo
Old May 1, 2007 | 06:57 PM
thetazmanjim
Default thanks
You guys are awesome! Thanks . It looks like this will be a job for this weekend. I'm working too late each day this week. I'll let you know. Thanks for all your help. Jim
Old May 9, 2007 | 06:23 PM
thetazmanjim
Default vss problems
I found the VSS ,I think, I would have to remove the exhaust system to reach it. What a pain. I will save this pleasurable feat for later when I have more energy.
Old May 9, 2007 | 06:25 PM
thetazmanjim
Default fuel filter
Oh yeah, I did replace the fuel filter and that didn't help. But, it's good to know that it eliminated that possibility.
Old May 11, 2007 | 09:21 PM
thetazmanjim
Default I'm a little smarter!
I bought an original shop manual for 1982 covettes on ebay and it has told me exactly where the VSS is and I will work on it shortly. I guess that one of you have been telling me all along that it was behind the speedometer in the dash. I just got the manual today. This is a real manual!
Old May 11, 2007 | 09:48 PM
DR.Jay's Avatar
DR.Jay
Do you have a picture of the VSS? My book shows nothing.
I believe this is it, but I could be wrong. It is mounted to the back of speedometer in the instrament cluster . You will have to lower the steering column a little, and remove the speedo, tach cluster to get to it.
The sensor buffer should be yellow in color with three wires coming out of it, and going to the sensor itself.
http://www.napaonline.com/masterpage...e+Speed+Sensor
