Where Do I Look??
Old Apr 30, 2007 | 08:54 AM
SPIKESDAD's Avatar
SPIKESDAD
Default Where Do I Look??
Standing if front of my 78 this mourning,it appears [is] the the drivers side of the car is one inch lower than the passenger side. It measures the same from front to rear, with passenger side one inch lower.
Ideas on where to check first ??
Old Apr 30, 2007 | 09:11 AM
SIXFOOTER's Avatar
SIXFOOTER
There have been several threads on this lately it seems. I would put it on as level a surface as you can, measure floor to frame, suspension and body points. That should give you a starting point. Check out the body mount bushings, how old is the suspension? Springs, suspension bushings? Has it been wrecked?
