Tach reads double
It would be difficult to explain by anything other than hosspower's suggestion: Its a 4 cylinder tach.
Do you have any other symptoms?
Does it read double all the time?
Does it return to 0 when you turn the ignition to RUN with the engine off?
Does it jump around?
What's your battery voltage. (The tach can be affected by low voltage)
This might filter out any ringing that the tach is reading as two pulses.
The filter ciruit is just a couple of resistors and caps.
Its R!, R2, C1, and C2 in this diagram:
Tach Filter
You can always test the tach using a modified AC adapter as I'm showing in this diagram.
If you apply 120Hz from a FWB rectified adapter, you should read 1800Hz.
I would not attempt this unless you have some electronics knowedge.
If you don't, find someone that does.
Tach Test
Shutting the engine off:
Switching off the ignition removes the electical power required to move the needle.
If you do this quickly, the tach will freeze at its last reading.
Power returns when you turn the ignition switch back to run.
There is no signal if the engine isn't running. It should read 0.
The chip is a national semiconductor LM1819.
They are obsolete. Good luck finding one.
Its easier to buy a new board on ebay.
The Gardner boards are highly rated.
Reads double when engine is running and in gear.
Reads correctly when in neutral.
I would think the tach circuit is working and you have either bad voltage,
or a bad signal.
I would:
Check your connection point as suggested above.
Check battery voltage when in gear.
Try a filter circuit
Just to clarify, your suggesting Gardner makes the tach printed wiring circuit boards and its easier to pick a new one up than attempt to find the semiconductor and replace it on the existing board?
Where is that board located? Behind the tach/speedo console?
Yes. The board is at the back of the tach in the dash.
You have to drop the steering wheel, take off the windshield trim,
take out the dash pad, and then the instrument panel will pull out.
Its a pain in the butt.
(This is how it comes out on my 76)
I was told it is probably a bad board. I will replace it the next time I open the dash up for another issue as I'm not tearing that apart again just for that circuit board. Taking it apart is easy compared to getting it back together.
thats what they said when I called in for technical support, so they sent me a new one... Same story different day, I think the circuit boards from MA are bad
This was about a year ago now. I have learned to live with it and mentally adjust by feel of engine.
If I blow the engine I guess I'll be able to justify a 'modest' upgrade.
Tach on the steering column. Someone did mention to me that sometimes the problem can be as simple as replacing the Tach Filter, but I see another reply that said he tried that.
I actually had the vendor bench test both of the boards I tried and they both worked fine when he tested them, so why they wouldn't work when I installed each of them is still a mystery, but I wasn't going to let it make me go mental, so the after-market unit suits me just fine because the car is a daily driver and I'm not sweating the fact that the original Tach refuses to work. Good Luck, mick
