Speedo Correction Gear???
Old May 1, 2007 | 06:32 PM
JT's72's Avatar
JT's72
1st Gear
Default Speedo Correction Gear???
1972 Turbo 400 trans; changed rear end gears from 336 to 308; car has 235-70-15 tires and is running about one tenth of a mile slow in a measured mile.What speedo gear needs to be put into trans to correct speed? Can reply here or to email--JosieL@Prodigy.net HELP!!!
Old May 1, 2007 | 07:40 PM
C3 Stroker's Avatar
C3 Stroker
Don't have the chart for part numbers for ratios, but this link may put you in the right direction. You will have to check the color gear presently installed, and use one that is about one tooth less. (Each tooth difference = around 3 mph)
http://www.tciauto.com/Products/comp...eter_gears.asp
Old May 2, 2007 | 09:49 AM
Bill Z's Avatar
Bill Z
Here is another option for you. Look down the web page. He has some external speedo adjusters for GM.
http://www.transmissioncenter.net/sp...n_______va.htm
To Speedo Correction Gear???
