Tach not working
Old May 2, 2007 | 08:24 PM
billd56's Avatar
billd56
Default Tach not working
Does anybody know if there is a way to see if my tach is working properly. Right now, even when the car is off, the needle seems to be "stuck".
Thanks for any help.
Old May 2, 2007 | 08:30 PM
gldnkngt's Avatar
gldnkngt
What's it doing, exactly?
Old May 2, 2007 | 09:49 PM
ddecart's Avatar
ddecart
SPARTAN
CI 3-4-5-6-8-9-10 Vet
CI-9 AutoX Winner
CI-3 Go Kart Champ
St. Jude '03-'04-'05-'06-'07-'08-'09-'10-'11
What year? mechanical or electrical tach?
If it's mechanical, you can reach up behind the dash and unhook the cable from the back of the tack. Then you should be able to spin the "****" on the rear of the tach to see if it moves while you spin it manually. If that works, the odds are the crossdrive gear in the distributor is stripped. Common problem.
Old May 2, 2007 | 11:05 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
The car is a 1981. Is it working other than staying at 1500 when off. If so, this is normal.
Old May 3, 2007 | 10:28 AM
gldnkngt's Avatar
gldnkngt
This is normal. The tach should go to zero when you turn the key on, but with the engine and key off, they usually settle in between 500 an 1500. That is normal for those years.
To Tach not working
