Power Antenna Problem
Old May 7, 2007 | 08:35 PM
randy007's Avatar
randy007
5th Gear
Default Power Antenna Problem
I removed an after market radio from my 70, and am installing a Delco (not sure if it's from a Corvette) radio and can't get the power antenna to work. I don't know how to wire the antenna to the radio. Please help!
Old May 7, 2007 | 11:14 PM
superdad60's Avatar
superdad60
Do you have three wires and an antennae cable
Hot (red)
Ground (black or go to frame near antennae mount)
Radio turned on lead (usually light blue or orange from radio)
Old May 8, 2007 | 08:51 PM
randy007's Avatar
randy007
5th Gear
I have the antenna cable, a red and a green wire.
Old May 9, 2007 | 10:43 AM
kortensi's Avatar
kortensi
Hey Randy,
Sounds like you have the same one I do.
If I remember correctly, the red should be power, the green should be to the radio for the power antenna connection and the grounding strap needs to be connected to the frame like this:
I hope this helps.
KO
Old May 9, 2007 | 12:34 PM
randy007's Avatar
randy007
5th Gear
Yes, that looks like my antenna, but I don't know where to hook the red and green wires to my radio. Out of my radio I have a yellow wire, a black wire and a gray wire. I have the radio working, just can't figure out the antenna. Thanks for your help.
Old May 9, 2007 | 01:44 PM
kortensi's Avatar
kortensi
On my 71 I attached the red directly to the fuse box for power.
The green should connect to the power antenna connection on the radio. If you don't have the wiring diagram you should be able to look it up online.
(I'm assuming that you are using an aftermarket radio that works with a power antenna.)
Old May 9, 2007 | 08:00 PM
randy007's Avatar
randy007
5th Gear
My wife bought me this radio on E-bay. It was supposed to be out of a 70 vette but I don't think it was. I believe that it is just a 70 Delco radio. How do I tell if it will work with a power antenna? The after market radio I took out had the power antenna hooked to a power booster. thanks
Old May 10, 2007 | 10:01 AM
kortensi's Avatar
kortensi
I don't believe that there is an easy way of wiring it in to a radio that old. There may be a way to crack open the radio and connect it to somewhere in there to activate it, but that is only a guess. I'm not sure how much power is needed to extend the antenna or if there is a spot inside the radio with that amount of power.
Maybe someone else here that is more of an electrical engineer can chime in.
Old May 23, 2007 | 01:01 PM
randy007's Avatar
randy007
5th Gear
I bought a different radio, this one works fine. Thanks for all the info.
To Power Antenna Problem
