Fitting Trim Rings
Old May 11, 2007 | 02:35 AM
Chris Farrer's Avatar
Chris Farrer
Default Fitting Trim Rings
I had difficulty removing my original trim trings some time ago and in fact slightly damaged them in the process. Is the correct procedure to deflate the tire before removing the ring as the clips go under the tire.
Old May 11, 2007 | 03:53 AM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
The trim ring clips don't go under the tire. Not even close.
Old May 11, 2007 | 02:02 PM
lincoln9's Avatar
lincoln9
To take off and put on the factory trim rings you don't need to pry them or hammer them. What you do is pust the center of the 4 clips inward one at a time with a large flat head screw driver and gently push the ring inwards or pull if removing. You won't damage a thing this way.
To Fitting Trim Rings
