0-60 in 3sec
http://www.wallaceracing.com/Calculators.htm
You could move the battery to the rear of the storage compartment on the passenger side for better weight distribution and balance.
Remove the front sway bar and make the front control arm bushings slightly oversize to get the maximum amount of lift.
Go to the tallest front springs you can find.
Drop the inner strut rod mount on the rear suspension to make the half shaft and the strut rod parallel. There will be no camber change when the rear suspension squats.
BigBlockk
Later.....
No need to be a smart hat Alan i metioned the bumbers to illustrate that i shaved off lots of weight all the small things combined.
and i took excatly 4kg = 8.8lb off the bumpers
Thank you Bigblockk thats some solid advice.
buy something or just modify your frame that allows you to
in set bigger tires. Probably cause problems if you want to
keep the convertible top frame in the car.
I know cars that run mid 6's in the 1/8 mile at about 105 mph and their 60' time is 1.35.. That means that they hit 60 mph after 1.35 seconds.. However, their 1/8 mile ET+ mph only shows 2.12 seconds.. That's a huge difference.. I 60' at 1.39 - 1.40 and I'm at 58.8 mph at the 60' mark based on the calculation.. It's not taking me another second to 60 mph... Therefore, my 0 - 60 mph estmation is about 1.5 - 1.6 seconds with my old setup..
I've been through all that to make my car hook and I know what I'm talking about. I have one of the hardest hooking C3's out there.. Soft front with 90/10's and stiff rear with QA1's (which you already have). I'd set the rear QA1's to about 10 clicks!
Here's my suspension setup:
213 lbs/inch Moroso Trick front springs (with 2 coils cut off = 250 lbs/inch final ratio)
Competition Engineering adjustable 90/10 shocks - set to 90/10
550 lbs/inch composite rear spring
QA1 rear shocks set to 10 - 11 clicks
All my launches are within 2 hundreds of a second.
My car is also about 2800 lbs (maybe slightly under without the nitrous bottle and slightly over with the full nitrous bottle)
There are some super cars that run 3.2 - 3.7 seconds 0 - 60 mph on street tires BUT most of them have the engine in the rear which really helps traction. Those times are also usually achieved at the drag strip where they have VHT on the track.. I HIGHLY doubt that you can actually get anywhere close to those times on the street in ANY car with street tires on the street..
I tried, but could not figure out the rest of what you are trying to explain with 2.12 seconds and your car at 58.8 and taking another second to go to 60 mph ????
60' times are only that.........0-60 feet, there is no correlation to a mph matching (on a linear scale) the time it takes your car to go to from 0-60 feet.
I just ESTIMATED my 0 - 60 mph time to be about 1.5 - 1.6 seconds as my best 60' time was 1.39. The mph calculator from the 60' time shows that I'm at 58.6 mph at the 60' mark in 1.39 seconds.. I should be able to pick up the additional 1.4 mph in less than 2 tenths which would put me in the 1.5 - 1.6 second range for 0 - 60 mph.
It's commonly known that a 1.35 60' time puts you at 60 mph at the 60' mark and I know someone that hits 1.35 60' times but only runs about 6.50 @105 mph in the 1/8 mile. Based on the 60' calculation, his 60' time puts him at 60 mph at the 60' mark after 1.35 seconds. The 0 - 60 mph calculation from his 1/8 mile stats calculates his 0 - 60 mph time to be 2.12 seconds. The 1/8 mile / 0 - 60 mph calculation is inaccurate for hard hooking vehicles! That's what I was trying to say..
LittleMouse - i agree, the frames i have been looking at are all setup for C4 or C5 suspension with much wider tirewalls.
Grandsport - thank you for the detailed setup description i can see that one of my first improvements have to be to loosen up that front end as you and others have pointed out, i think ill do 1 thing at a time and see where it takes me.
Here is my plan with runs in bewteen each modification.
take off the semicoilovers and put in some 250 lb springs
and change front shocks to some 9/10s
change rearend to 3.08 and up my revlimiter to 7k preferrably hitting 60 in first.
Get some stickier tyres, have to look up what my options are for 20" rims.
try some runs with near empty tank and some with full tank, if the full tank works better then i prolly have to put on some meat in the back.
If there is no change with this combined, then my winter project is probably gonna be a new frame with a C5 setup.
Thank you for the help everyone i will keep you posted on my progress or failures
it will be a month or so before i have the time, im off to Disneyland in Paris with the family for the next couple of weeks.
it will be a month or so before i have the time, im off to Disneyland in Paris with the family for the next couple of weeks.However, if you want the best possible acceleration, you will need them set to 90/10 but your handling in corners will suffer.
Another option are the QA1 front shocks.. The expansion on those shocks has to be set to the lowest resistence (1 click) for best results. However, the QA1's are about 2 - 3 times more than the Competition Engineering 90/10's..
BTW - taller rims = less traction. What gives you traction is taller sidewall and if you have tall rims, you have less sidewall.
For example, I have had 1.80 60' times at the track with 28 inch tall street tires with 15 inch rims (tall sidewall) but I've never been below 1.95 60' times with 26 inch tall street tires on 17 inch tall wheels.. The reduced sidewall definetely hurts traction but helps handling..
I doubt that there are any sticky tires available for 20' tall rims.. If you REALLY want to hit the 3 seconds, I'd recommend to get a inexpensive set of 15' wheels with Mickey Thompson Drag Radials 275/60R15
BTW, the C5 frame and suspension is actually a disadvantage for acceleration as the composite front spring doesn't allow the front to lift too much.. C5 suspension is much better suited for road racing..
