emergency brake console
Old May 14, 2007 | 01:13 PM
Lilfur's Avatar
Lilfur
Default emergency brake console
I am trying to remove my brake console , All I seeare 4 screws 2 on each side. I have removed these, and it still seems to be supported. What is the trick???
Old May 14, 2007 | 01:22 PM
S489's Avatar
S489
some also have a bolt. it is right in front of the glove box. go at it from the battery box. it is a pita to get to.
BB68Vett's Avatar
BB68Vett
There is another screw supporting it from behind. I believe it is accessed from the storage compartment behind the passenger seat. The is a little gap in there. Reach in and loosen the nut. Something tells me it's a 7/16 nut, but I can't remmeber for sure.
Old May 14, 2007 | 02:26 PM
7T1vette's Avatar
7T1vette
BB68 is right. The bolt head is a 7/16" hex. Remove the pull-out bin from the jack storage compartment; get a 7/16" open end wrench and try to fit your hand/wrench in there to work it out a little at a time. If you get it out OK...don't put it back in [like it was]. Cut the head off the bolt and round off the upper shank. Install this "stud" back in the rear console and push the rounded-off stud through the carpet and into the mounting hole. Then put the housing back in place and put the screws in. You'll never have the same problem again.
To emergency brake console
