gauge check
Old May 19, 2007 | 04:49 PM
7Deuce's Avatar
7Deuce
Default gauge check
Just wanted to post what readings I get from my gauges and see if everything is normal.
Water temp: When warm, the needle rests at the mark 1/2 between 100 and 210 on the gauge. It sticks here 90% of the time. If I'm in stop and go on a hot day it may creep up a little, near 200 but never over that.
Battery: While driving the needle rests a hair to the right of center (the + side). Never really changes from this position even with stereo, lights, etc running.
Oil Pressure: Once warmed up the needle will rest at 35 psi at idle. Anything from cruise to wot it is at a little under the 70 psi mark.
Fuel: Well, this one tends to swing from F to E pretty quickly
Battery: Mine always reads 9:15. I guess time never changes in my car.
How do these reading compare to what you guys see in your cars? Does everything seem normal?
Old May 19, 2007 | 06:34 PM
7T1vette's Avatar
7T1vette
My clock reads about half past 2.... Yours must be "digital".
Old May 19, 2007 | 08:17 PM
gldnkngt's Avatar
gldnkngt
I'd be really pleased with these readings.
Old Aug 14, 2007 | 10:20 PM
vetteguy75's Avatar
vetteguy75
LA Events Coordinator
The oil pressure gauge, battery & temp gauge....just like mine....are those readings normal??
To gauge check
