'69 Original Engine?
Old May 22, 2007 | 08:26 AM
davweb01's Avatar
davweb01
Default '69 Original Engine?
I have a '69 coupe that has been redone. It is a small block and I am wondering if the block/heads are 300 or 350 horse components. How would I confirm if it is the original engine and the correct HP rating? Casting codes, location of codes, etc?
Thanks to all you Corvette guys and gals out there.
Old May 22, 2007 | 09:22 AM
Duke94's Avatar
Duke94
This will do it for you. Engine code it stamped on a pad at the right front corner of the block.
Old May 22, 2007 | 09:23 AM
Disco_Mike's Avatar
Disco_Mike
the original block as the vin stamped on the block.
There is an area on the front of the block to the upper left of the timing chain cover. this is where the vin of the car should be stamped if it is the original.
as for the other casting codes and location, Ill let the more experienced members chime in.
Old May 22, 2007 | 10:02 AM
SoCalErv's Avatar
SoCalErv
Army
A couple things to check:
1. 350hp only came with a manual transmission
2. Heads were 3921786 or 3927187
3. Carb should be a rochester 7029207
4. Broadcast code is HY or HW on the VIN pad
5. Valve covers on a 350hp were cast aluminum with ribbed top
Post your VIN and people can tell you exactly what that block was designed for. Your VIN will look similar to this on the passenger side above the water pump, in front of the valve cover:
19S719311 V0224HY
Old May 22, 2007 | 01:23 PM
davweb01's Avatar
davweb01
The car is VIN 194379S711869. Also, it does have an automatic transmission.
Old May 22, 2007 | 03:17 PM
SoCalErv's Avatar
SoCalErv
Army
That is the VIN you probably pulled of the registration. Pull the numbers off the engine pad, these are a partial VIN with builld date and suffix code. Should look like this : 19S716618 V0211HZ
Old May 22, 2007 | 06:44 PM
davweb01's Avatar
davweb01
Okay, this what I saw on the engine itself.
Casting #3932386
Numbers on Pad, 19S711869 V1216HZ
Looks like the original engine, right?
Old May 22, 2007 | 08:17 PM
FrankVincent's Avatar
FrankVincent
Account disabled by user request 5 Jan 09
Casting #3932386
yes'sir!!
Your serial number plus December 16, 1968 engine build date in Flint for a 350/300hp with automatic transmission ... car build date of January 4th, 1969.
Old May 22, 2007 | 09:30 PM
davweb01's Avatar
davweb01
Thanks for the help..........I was going to attach a couple photos of the car but don't how to do it.............
To '69 Original Engine?
