Gear Ratios
Old May 22, 2007 | 09:11 PM
rcsron's Avatar
rcsron
Default Gear Ratios
How do I determine what gear ratios I have in the rear.
71 Corvette Stingray 350 CID Manual trans
Old May 22, 2007 | 09:21 PM
mrvette's Avatar
mrvette
Since on any of performance cars this age group, you need forget numbers entirely....jack up the rear, support with tires off the ground and suspension LEVEL....and NOT by the struts....under the knuckles or on the T arms....
tranny in neutral....grab a majic marker, strike a spot on a tire, strike a spot on the driveshaft.....spin the drive shaft being real careful to count the amount of revs untill the tire spins ONE revolution...
now you WILL have to calculate visually the percentage of one incomplete revolution of the driveshaft.....
so say you have 3 and 1/3 rev.....that means you have a 336 rear....
you have 3 1/2 revs that a 355 rear....
you have 2 3/4 revs....that a 2.73 rear.....
you have 4 1/10 rev....just a hair over 4 even....you have a 4.11 rear....
etc.....
with out taking it apart it's the ONLY true way for you to tell.....
Old May 22, 2007 | 09:38 PM
a1sensei's Avatar
a1sensei
It's easy, I used a china marker on the tire and drive shaft, then lay under the car watching the shaft as my son turned the wheel. God bless, Sensei
To Gear Ratios
