Purple Starter wire..
Old May 26, 2007 | 02:10 PM
collectskulls's Avatar
collectskulls
Default Purple Starter wire..
I have searched but guess i am just today
where does the purple wire go? please
Old May 26, 2007 | 02:32 PM
Duke94's Avatar
Duke94
The purple wire goes on the "S" terminal on the solenoid from the clutch start switch or neutral switch if auto trannie. It is this wire that supplies 12V to engages the solenoid to spin the starter.
Old May 26, 2007 | 03:02 PM
collectskulls
so the purple and yellow go to the s then?
Old May 26, 2007 | 03:12 PM
...Roger...'s Avatar
...Roger...
No they do not.Do you have HEI or a points ignition?
Old May 26, 2007 | 03:20 PM
...Roger...
Wow things are slow today.The wires you have are for a points type ignition.On the starter there should be an S term. and an R term. The purple goes on the S and the yellow goes on the R. Your red wire is right but make sure to put the battery cable on with the red wire.Note-the small black wire is the ground for the wipers DONT put it on with the red wire even thiugh the hole is big enough-it goes to the block or starter mounting bolt.
Old May 26, 2007 | 03:52 PM
Duke94's Avatar
Duke94
The yellow goes from the "R" terminal on the solenoid to the + terminal on the coil if you have point ignition. If you have HEI, I don't think the wire is used.
Old May 26, 2007 | 03:59 PM
collectskulls
Originally Posted by DWncchs
Wow things are slow today..
I know I am having a hard time computing 2+2 today for some reason
Thanks all of you for the help
Old May 26, 2007 | 04:08 PM
mrvette's Avatar
mrvette
hehe....since you outta yours (skull that is), can I borrow it???
Old Jun 4, 2007 | 03:26 PM
vettlag's Avatar
vettlag
my wire is green and white 85 cant get my to start changed shifter is there a differt wire purple somewhere else
Old Jun 4, 2007 | 03:33 PM
lars's Avatar
lars
This is the C3 Forum... C3s use purple and yellow wires to the starter.
Old Jun 30, 2007 | 04:20 PM
SargeZ06's Avatar
SargeZ06
c-skulls
So where did you put the purple wire? Also I ran my small black wire to the bolt that attaches the starter to the engine. Not to the starter itself.
71Canam
To Purple Starter wire..
