Drive Shaft Removal
Old Oct 23, 2001 | 06:20 PM
Tom Johnson's Avatar
Tom Johnson
Default Drive Shaft Removal
71 350/270 Automatic Can the drive shaft be removed by unbolting the u-bolts from the the transmission end?
Old Oct 23, 2001 | 07:09 PM
jerryp58's Avatar
jerryp58
Default Re: Drive Shaft Removal (Tom Johnson)
You have to remove the U-bolts on the differential end, then you can slide the driveshaft yoke out of the trans. Tape up (or somehow secure) your U-joint end caps so they don't come off and spill needle bearings all over the place.
Old Oct 23, 2001 | 07:44 PM
GTR1999's Avatar
GTR1999
Default Re: Drive Shaft Removal (jerryp58)
Also watch out you don't pull the yoke out of the tranny or you'll have a big oil leak.
Gary
Old Oct 23, 2001 | 09:59 PM
Tom Johnson
A while back a member stated you could do this, which would save a lot of work. You wouldn't have to pull the front differental mount.
Old Oct 23, 2001 | 10:08 PM
Pedro'74's Avatar
Pedro'74
There's no need to pull the diff mount. All you need to do is use an extension of appropriate size to get to the bolts from the front of the crossmember.
-Pedro
Old Oct 24, 2001 | 08:53 AM
norvalwilhelm's Avatar
norvalwilhelm
I have a 75 and there is no way you can remove the driveshaft by unbolting it at the rear end then sliding it back out of the transmission. I have to remove the front universal by removing the u bolts then with a long extension remove the rear end u bolts then slid the driveshaft out the front. Then the slip yoke can be removed. If I am wrong then in the last 2 transmissions swaps I have gone to alot of extra expense obtaining special slip yokes with removable u bolts.
Old Oct 26, 2001 | 11:25 PM
jerryp58's Avatar
jerryp58
Default Re: Drive Shaft Removal (norvalwilhelm)
Norval, I sit corrected. It's been less than a year since I last pulled my driveshaft, but that's exactly what I did (+ push the yoke forward as far as it would go so that the driveshaft would clear it).
A mind is a terrible thing to waste :crazy:
Old Oct 27, 2001 | 12:02 AM
redc3vette1's Avatar
redc3vette1
Default Re: Drive Shaft Removal (Pedro'74)
-Pedro
yea just us an extension just got finished doing mine
To Drive Shaft Removal
