Freeway Flyer Gears
Old Jun 5, 2007 | 12:56 AM
745400's Avatar
745400
Default Freeway Flyer Gears
Just about ready to have this thing put together. 540 BBC w/AFR 315heads and EFI should be between 700-750 hp with a 4L80E and Nitto drag radials.
I want to cruise at low rpm on the freeway so I've been thinking about using 2.94 gears. I'm only driving on the street and figure it should have plenty of power to pull at low speed.
I saw ML67 is running 3.08 gears. Anyone else with lots of power running a similar gear?
Old Jun 5, 2007 | 10:07 AM
international blue's Avatar
international blue
What transmission....? You may want to consider a tranny swap!
Old Jun 5, 2007 | 11:24 AM
big_G's Avatar
big_G
You already have an overdrive. You could use 3.08's.
To Freeway Flyer Gears
