I recently got my original tri-power set-up, so today I installed the (3937797) intake (onto the 3919840 heads) and I have this gap around the gasket, where the exhaust crossover is, and I don't know if this is ok or if it will be a problem?
I mean if I were to trim the gasket around the intake, it would expose more...so is this how it was originally or what?
I would just like a second opinion on this please.
Is that the crossover port on the head I see by the arrow? If so its definately not right
Yes it is, and I am using the replacement gasket, which is what I don't understand, because the intake itself only seals the center exhaust crossover port. The head has a center square and outside square and that's what I don't understand...I mean I have all original equipment and this is what it is.
I want to say yes because I dont think that channel goes anywhere.I dont work on enough big blocks to give you a definent answer.You better wait for some of the big block guys to respond.
edit -- I sent 427Hotrod a pm I think he will have an answer.
Well, first off..yes it will work. It'll look funny, but it won't hurt anything.
I think you just have a gasket that is made incorrectly. You could use the Fel pro race type gaskets. They are solid across that area without the indentations that follow intake curvature and will cover the whole section. But I'm assuming you're after a somewhat stock look? If nothing else, the race gaskets do look nicer.
What gasket set is that? There's not by chance a right and left one with a different plate over the heat riser passage is there? Did you try flipping them around? Is it the same on both heads? The water passages did line up right? It appears to be on right from looking at intake port area.
JIM
It's a Fel Pro stock gasket set, I did flip them around just to be sure before tacking them to the heads, after I tacked them I checked that all lined up, it did, so I torqued to 30ft/lbs in 5lb increments. (I used RTV not the rubber end seals)
The other gaskets I looked at had no hole for the exhaust crossover.
So I take it nothing comes out of the outer square, so they technically don't have to be covered, right? The intake wouldn't cover it regardless, but I am confused if a gasket is 'supposed' to?
