1981 code 15
Old Jun 10, 2007 | 10:43 AM
Lois Lane's Avatar
Lois Lane
St. Jude Donor '08-'09-'11
Default 1981 code 15
torque converter is not locking in. I get temperature to the water temp. guage in the dash, but trans. is not getting info it needs to lock up the converter. Any ideas?
Old Jun 10, 2007 | 12:39 PM
CA-Legal-Vette's Avatar
CA-Legal-Vette
The sensor that the CCC uses for the lock up circuit is not the same as the one used for temp gauge. I don't think it's the one on the right side of the head either, which is for auxiliary fan.
I spent a few minutes this morning with the service manual trying to figure out which is the sensor used for this circuit. Hopefully someone will chime in. Otherwise, I'll keep reading.
Old Jun 10, 2007 | 02:31 PM
SIXFOOTER's Avatar
SIXFOOTER
It should be the one next to the thermostat. Thats the only other temp sensor in there besides the TVS' used for the emissions stuff
Old Jun 10, 2007 | 03:39 PM
...Roger...'s Avatar
...Roger...
I would be looking at the vacumm sensor(map sensor) mounted on the firewall next to the air relay which is between the wiper motor and the drivers side hood latch.It should have a vacumm line and 3 wires gray,green and black.
EDIT-Oops Sorry I was thinking about a 1980 with no computer.
Here is a testing procedure that you should go through step by step.Its going to be pretty hard to help you via a computer.There are lots of points you have to check.Hope this helps and sorry for the wrong info.
Old Jun 10, 2007 | 04:27 PM
a1sensei's Avatar
a1sensei
Good post DW! God bless, Sensei
Old Jun 10, 2007 | 06:20 PM
Lois Lane's Avatar
Lois Lane
Thanks for the replies. We'll keep looking. Not sure if I can do the flow chart test. What test light do I need? If it is the ECM - where do I get one? The car idles high (1500 rmp or so) for a while when started.
Might try the sensor next to the thermostat. Just got the car yesterday so we've got some things to work on. Quite a difference from the other 2 vettes!
Old Jun 10, 2007 | 07:00 PM
Tim81's Avatar
Tim81
Wow thats a nice car. Chk for post by UKPaul, he has a pretty good write up on checking the TCC. Good Luck
Old Jun 10, 2007 | 10:42 PM
...Roger...
Nice !!!!!! My 80 was your cars twin.
Old Jun 10, 2007 | 11:32 PM
Big2Bird's Avatar
Big2Bird
The TC lock up is controlled by the vehicle speed sensor in the speedo, and over rided by the brake switch.
Old Jun 11, 2007 | 09:10 AM
SIXFOOTER's Avatar
SIXFOOTER
WB Bird
Old Jun 11, 2007 | 07:00 PM
Spolioli's Avatar
Spolioli
I'm guessing that there are two or three water temp. sensors on this motor. One sends signal to the water temp. guage in the dash and is probably located in block or head on the drivers side. Another on the block or head on the passenger side that sends temp. to the aux. fan. And one that sends temp. to the ECM, probably mounted in the intake manifold. Thats the one that probably controls torque converter lock up. The car needs to meet at least three conditions to lock up the torque converter. One is proper speed and there is a sensor around the speedometer for that. Second is engine warm up. The torque converter doesn't lock up when the engine is cold. And I think rpms is the third. Just my guess.
Old Jun 11, 2007 | 07:08 PM
CA-Legal-Vette
At least four that I know of. The one in the drive's side head is for the temp gauge. The one in the passenger side head is for the auxiliary fan. There are two thermostatic vacuum switches in the thermostat cover. I don't know if any of these three is responsible for the signal to the CCC.
Old Jun 11, 2007 | 08:37 PM
Big2Bird's Avatar
Big2Bird
Correct. The ECM temp sensor is located on the intake manifold, just past the stat housing.
The stat housing vac sw operate the heat riser, and the EGR enable.
Old Jun 12, 2007 | 08:30 PM
Spolioli's Avatar
Spolioli
I fixed the problem with the torque converter not locking up on lois lanes 81. It was the temperature sensor located in the thermostat housing behind the air pump. I took the coupler off and tested for voltage across the ground and the lead while the key was on and i got 5 volts reading to the ECM(anything over 4 is good). Then I removed the sensor and checked resistance across the pin in the middle and the inner sleeve and got 700 ohms(anything less than 1000 ohms is good). So it just wasn't making good contact. I looked at the pin in the sensor and at the sleeve in the coupler and noticed that the pin was a lot smaller diameter than the sleeve of the coupler. So I bent the pin over just a little bit and walla. The car now has a locking torque converter in 2nd and 3rd gear.
To 1981 code 15
