72 temperature sending unit cross reference?
Old Jun 11, 2007 | 09:17 PM
elkhart-grn's Avatar
elkhart-grn
4th Gear
Default 72 temperature sending unit cross reference?
I apologize if this has been covered; I couldn't find anything. I have a 72 small block. My new heads (Dart) have a 3/8" NPT port for the temperature sending unit. The OEM sending unit is 1/2" NPT. Does anyone know if there is a 3/8" temperature sending unit out there that will work?
Thank you,
David
Old Jun 11, 2007 | 09:33 PM
Durango_Boy's Avatar
Durango_Boy
Here this one is cheap...
http://cgi.ebay.com/ebaymotors/STEWA...QQcmdZViewItem
...any Parts America stores, TSU64 is the GP Sorenson part number.
I don't know the GM part number yet but I'm still looking.
Old Jun 11, 2007 | 09:37 PM
Durango_Boy
Here's a link to an Oreilly cheap brand.
http://www.oreillyauto.com/EW3/Produ...cycleCount=650
Old Jun 12, 2007 | 01:24 AM
SteveG75's Avatar
SteveG75
You need a sender with the right resistance so the gauge reads correctly. Using just any old 3/8" sender will get you wrong readings.
Contact Lectric Limited. www.lectriclimited.com They have senders with the correct resistance. They know what they correct resistance is for the C-3's (it varies by year as well) and could probably point you in the right direction.
Last option is to do what I did. Take the head to a machine shop and have them make the 3/8" NPT hole into a 1/2" NPT hole.
Old Jun 12, 2007 | 10:51 AM
elkhart-grn
4th Gear
Default lectriclimited
Lectriclimited is of no help. They don't have anything, and they wouldn't even tell me the corect resistance.
Old Jun 12, 2007 | 11:17 AM
mrvette's Avatar
mrvette
I gave up, not realizing the thing would be such a bitch, and so put in a later say '99 Ford pickup sending unit, which is electrically differant...and took the square looking ceramic resistors off the back of my '72 gauge and dialed in something that works fairly close in the regions you are concerned about....180-220 are dead nutz on...
I did state the values once on this forum, so maybe do a search....I forget, and don't have info handy now....
Old Jun 12, 2007 | 12:59 PM
pws69's Avatar
pws69
220 degrees = 70 ohms
200 degrees = 90 ohms
180 degrees = 115 ohms
160 degrees = 140 ohms
120 degrees = 250 ohms
100 degrees = 340 ohms
Old Jun 12, 2007 | 03:15 PM
Durango_Boy
This is a good option that can also be done in your own garage. Using the thread size of the sender go buy a drill bit and tap for that size. Tap it yourself.
Old Jun 12, 2007 | 03:16 PM
Durango_Boy
That's great info. So you're supposed to use the highest degree mark on the gauge to check that list? So if my gauge reads to 200 I would want a 90 OHM sender?
To 72 temperature sending unit cross reference?
