nervous steering
Old Jun 12, 2007 | 11:19 PM
happiedazs's Avatar
happiedazs
Default nervous steering
I totally replaced the entire front end of my 75 vet-- new springs, bushings, ball joints,tie rods, idler arm, shocks, power steering pump, hoses, valve & piston. Also replaced all 4 tires. Then a 4 wheel alignment (but no rear end tow alignment yet and the rear tires have far too much tow-in by 3 times). I notice that when I'm driveing on the highway over 65, I have to make too many back and forth adjustments to the steering wheel. It seems that there is a little too much left to right play before the wheels turn. My mechanic who installed all this stuff say eveything is tight. Is there an adjustment in the steering box or someplace else that can tighten this up for me --- or what else should I check.
Old Jun 12, 2007 | 11:51 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
I see a big omission from your list of replaced parts - the rag joint between the steering column and steering box. If it's worn out, you'll have to turn the wheel a bit before the box starts turning. That can lead to some very interesting steering situations, and too many repair shops ignore the danged thing.
Old Jun 13, 2007 | 01:21 AM
RIJVETTES's Avatar
RIJVETTES
Finish the job with a new rag joint. I'll bet you'll be happy with the result.
Old Jun 13, 2007 | 09:43 PM
vette blue's Avatar
vette blue
Did you check for play in the steering box? Did you change the steering box?
Old Jun 13, 2007 | 10:03 PM
72rdstr's Avatar
72rdstr
Same work and same issue (I did adjust the box). I'll check my rag joint. Mine will occasionally JUMP into a groove (from heavy trucks on city streets) and scare the bejezus out of me.
Old Jun 14, 2007 | 02:03 AM
OzzyTom's Avatar
OzzyTom
My issues with front end darting left and right on every undulation was remedied by new tyres and a proper 4 wheel alignment.
You have to find a workshop that knows how to setup these ol' girls properly. Many workshops which work on a fixed price alignment will NOT spend the necessary time to do the job properly. It takes time, especially if shims need to be inserted/removed for the rear.
I found this out after my third wheel alignment.
My front wheels had 2 degrees toe-out, rather than toe-in..... and that was the main culprit for the instability.
Just a suggestion, as you mentioned you have issues with the alignment.
cheers
Old Jun 14, 2007 | 08:36 AM
GTR1999's Avatar
GTR1999
I can answer all your box questions. PM me and I'll get you info.
Old Jun 14, 2007 | 09:24 AM
Ken74Conv's Avatar
Ken74Conv
I would suggest rebuilding and aligning the rear suspension. The rear suspension has an amazing influence on the handling of the cars, especially at higher speeds.
Old Jun 14, 2007 | 09:38 AM
taylorsk8's Avatar
taylorsk8
Just finished replaceing my rag joint. Helped quite a bit. Took out about 2" of hand play on the steering wheel. I would definetly replace it if yours is origional. Mine was rotted and had slotted holes!
T
Old Jun 14, 2007 | 06:11 PM
jcswm's Avatar
jcswm
Whenever you get an alignment on ANY car ask for a print-out... It's the only way to know if your car was done right. even if you don't understand the results scan & post it here and lots of us know how to read the results & help out.
Old Jun 14, 2007 | 07:11 PM
glenn64vette's Avatar
glenn64vette
Ok, I was old school alignment--toe done in inches. On the read outs now is degrees. Can someone translate?
Old Jun 14, 2007 | 08:35 PM
ajrothm's Avatar
ajrothm
WHere is a good place to get GOOD rag joints...my car has the major slop in the steering wheel also...My car drives and steers good, its just got a ton of slack in the wheel before it starts to turn. I am sure my car has the original rag joint...
Is there a good brand to get that bolts up like the original? I know some of the aftermarket joints use different bolts etc..
Old Jun 14, 2007 | 11:51 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
The shop manual should have both inches and degrees listed. If not, I know VB&P does. I worked for Hunter for two years, and I don't think I ever heard of a conversion formula.
Old Jun 15, 2007 | 12:32 AM
Trent Mayo's Avatar
Trent Mayo
Another thought would be to replace the power steering control valve. My car would make an immediate left turn as soon as I let go of the steering wheel, even just sitting still until I replaced that and the slave cylinder. Hope that helps! Good luck with it!
Old Jun 15, 2007 | 07:19 AM
jcswm's Avatar
jcswm
Proper bleeding and adjusting the controll valve might have also fixed that.
Old Jun 15, 2007 | 10:42 AM
Jim Shea's Avatar
Jim Shea
The two OEM flexible coupling assemblies are:
1968 and early 1969 (full round splines - no flat) GM #7806391
Late 1969 through 1982 (flange has machined flat) GM #7818568
I just ran both part numbers through GMPartsDirect and both come up as good numbers. So they should be available through any GM dealership for lots of $.
Unfortunately, I am losing confidence in the full assemblies and the repair kits that are available on the aftermarket. If you attempt to purchase a flexible coupling assembly from a Corvette supplier, I would question if they are providing an original GM OEM part or something else (like from China!). If the supplier acts dumb like he/she doesn't know, you are probably getting a part from overseas. The overseas type parts have resulted in steering wheels being upside down.
Jim
Old Jun 15, 2007 | 01:57 PM
Casper's Avatar
Casper
My '82 would dart around like that. A four wheel alignment fixed that.
To nervous steering
Old Jun 15, 2007 | 02:04 PM
Casper's Avatar
Casper
As a last resort or a quick fix for a sloppy wheel you can also tighten down the worm gear. Just don't tighten it down any more than necessary.
Old Jun 15, 2007 | 02:41 PM
GTR1999's Avatar
GTR1999
I wouldn't advise this unless the person is very understanding of the procedure. I replaced a lot of gears that were worn out by over loading the on-center setup.
I use only GM rags. Buy them while the dealers still can get them. About $90 each
Old Jun 15, 2007 | 04:05 PM
din1780's Avatar
din1780
7th Gear
I also replaced from A - Z in the front even thought must parts were still in good shape, also poly bushings in the rear, still wandered in ruts, finally upon using alignment specs from VBP (I think) and changing my tires, it finally handles well, it's now enjoyable to drive even over rough roads etc. In my case replacing the tires and good alignment is what did the trick.
