Mangled Secondary Jets - Picture Included
Old Jun 15, 2007 | 01:47 AM
csams's Avatar
csams
Default Mangled Secondary Jets - Picture Included
Well....I have been trying to get my Quadrajet back in running order...got the stock primary and secondary rods to replace the junk that was in there.
Tonight I was getting ready to put it back together when I noticed the mangled secondary jets. Looks like someone tried to 'drill out' the left one and only partially mauled the right one (see picture).
Wondering if there is anything that can be done with these secondary jets since you can't buy new jet inserts (like you can for the primaries).
BTW....I had this carb rebuilt and recolored here in the Seattle area about a year and a half ago...the car has never run quite right...I didn't suspect the carburetor until I started digging into it. I am now very disappointed the shop never mentioned any of this to me. I had to find out on my own that the rods were not stock and that these jets were all messed up.
Old Jun 15, 2007 | 11:27 AM
merlin5353's Avatar
merlin5353
St. Jude Donor '07-'08-'09-'10
That really sux!!
Old Jun 15, 2007 | 11:44 AM
a kungfu mastah's Avatar
a kungfu mastah
new casting?
Old Jun 15, 2007 | 11:47 AM
csams's Avatar
csams
Originally Posted by a kungfu mastah
new casting?
No, this is an original 7042203 Q-jet that I got from a guy in San Antonio. Had it recolored and rebuilt by a local shop.
I am wondering what options do I have to fix those jets?
Old Jun 15, 2007 | 12:47 PM
Scott Marzahl's Avatar
Scott Marzahl
Nasty, I wonder if you can EZ out those jets?
Old Jun 15, 2007 | 12:49 PM
S489's Avatar
S489
only thing i can think of is to cut apart a donor. i have a donor that i've cut for other parts, but not the rear jets, so don't know exactly what's going on there. just hope they didn't screw up the casting when they drilled out the originals . . .
Old Jun 15, 2007 | 12:55 PM
Scott Marzahl
It looks like those are what is left of the jets, the heads are drilled off and the jet body is drilled out unless I'm not understanding this correctly. Where is Lars?
Old Jun 15, 2007 | 01:02 PM
ptroxx's Avatar
ptroxx
From: Henderson Nv-Rohnert Park/Sonoma C o. ca/born in NY Rockaway Beach.
Thats what i was going to say..Ask Lars..
Old Jun 15, 2007 | 01:17 PM
S489's Avatar
S489
here are the only handy pics i have near the area of interest (for ref):
Old Jun 15, 2007 | 01:19 PM
Kalway's Avatar
Kalway
Those almost look like you could some how tap em out and put in some from another one. However it may just be best to replace that whole part of the carb...
We'll just have to wait till we here from the man Lars to see what he says.
Old Jun 15, 2007 | 03:42 PM
BigBlockk's Avatar
BigBlockk
I have heard of these being removed and jets being installed. The biggest problem is probably getting them out without boogering up the carb body. You would also need to be careful about getting the controlling surface of the jet in the correct position. If it is a little off you could tune around it using different secondary rod hangers but you would need to get it close.
It is salvageable.
BigBlockk
Later.....
Old Jun 15, 2007 | 04:20 PM
SteveG75's Avatar
SteveG75
The secondaries do not have removable jets. There is just a machined hole.
Old Jun 15, 2007 | 09:40 PM
BigBlockk's Avatar
BigBlockk
If this is in refrance to my post above, I am well aware of this. The point is that I have seen these removed and screw in jets put in their place. Of course this involves tapping the holes.
It's worth it in a numbers matching situation.
BigBlockk
Later.....
Old Jun 15, 2007 | 10:14 PM
longbros's Avatar
longbros
No problem. Find your self a donor. One of my jets was damaged. They are very thin washer shaped pieces of stainless that are held in place by a retainer that is pressed in. You can carefully remove the retainer and jets from the donor and put them in your carb. Then use an appropiate size tool to tap the retainer back in. They are not in very tight, or at least mine were not. As I recall, all Quadrajets used the same size secondary jet.
Old Jun 15, 2007 | 11:40 PM
csams's Avatar
csams
Anyone have a 'donor' quadrajet in the Seattle area that I could steal the jets? Considering that it is a numbers matching carb I would like to find a way to use it.
Old Jun 16, 2007 | 02:13 PM
Scott Marzahl
We still have some junk yards in Seattle that would have one, or I see them on Craigslist every once in awhile for around $25. I'd email Lars and maybe he knows of a place that he uses to fix this problem.
V8fastcars@msn.com
Old Jun 18, 2007 | 10:34 AM
lars's Avatar
lars
Once the secondary metering plates have been drilled and mangled, the carb is junk. The steel inserts are cast into the float bowl and are not replaceable. Installing a screw-in jet does not produce the same pressure drop across the metering hole due to the thickness (depth) of a jet versus the thin steel metering plate in the carb.
Lars
To Mangled Secondary Jets - Picture Included
Old Jun 18, 2007 | 11:07 AM
olescarb's Avatar
olescarb
we do have the original secondary jet/restriction in stock if you do need them and the supplier i deal with has 800 of them in stock.
i have changed them in the past with no problems
henry @ oles carb
Old Jun 18, 2007 | 11:12 AM
lars's Avatar
lars
Looks like Henry has the fix.
Old Jun 18, 2007 | 12:06 PM
Wrencher's Avatar
Wrencher
After looking at you picture a few times, it looks like one of the restrictor shims is already gone and the other one is mangled a bit. I'd guess that the one that's missing hasn't necessarily been drilled and may take a new shim just fine. Because of your numbers issue I'd definitely try to fix it. Even if it isn't dead nuts perfect it will be real close and will probably work well. Nice to see thet those restrictors are available!
Hans
