Help me understand C3 A/C systems
Old Jul 11, 2007 | 04:38 PM
  #41
SIXFOOTER's Avatar
SIXFOOTER
I use painters tape for most of that kind of thing, its secure and comes off when I want it to, works good for hose ends and that sort of thing. Inlets like on a HB unit are another matter, usually a blue shop towel and maybe some tape, cheap and easy
Old Jul 11, 2007 | 10:38 PM
  #42
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Originally Posted by shafrs3
1) Is it a valve or a port, can you post a picture of it?
Here's a lousy pic of it - it's the cross-shaped thing inside the line.
Old Jul 11, 2007 | 11:28 PM
  #43
brookman's Avatar
brookman
that is the orfice tube. It is required for your ac to work
Old Jul 12, 2007 | 01:23 AM
  #44
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Do I need a different one for R134a? How does it come out?
Old Jul 12, 2007 | 02:47 PM
  #45
Overlord's Avatar
Overlord
From: Crush your enemies, see them driven before you, and hear the lamentations of the women TX
Yes I would because:
1) I understand some of these kits locate the evap inside the cabin and due away with the evap box in the engine bay, obviously a good thing.
2) They replace the dampener vacuum controls with modern methods.
You might post a new thread here asking for anyones experiences with these products, I'd like to hear them myself.
I have a pic of the general engine bay, not much to see or different except the Sanden compressor. My system is OOC due to a slow leak, another project scheduled for this winter.
Once I get other projects on the car out of the way I'll probably be getting an aftermarket kit. The '75 was an original AC car but now there's no equipment forward of the piping coming out in the engine compartment. I don't have the knowledge to piece one together from scratch and not all that sure that all the connections still exist on the wiring harness. Like another tech at work says, "I didn't want to learn that today". I'd rather have cookbook directions to follow.
Old Jul 12, 2007 | 06:37 PM
  #46
shafrs3's Avatar
shafrs3
No different but it's also a screen, replace it while you're there, needle nose pliers will get it out.
Retro-fit kits don't replace the orifice, the only thing in the kit is the adapters for the different gauge fittings unique to 134a, and the refrigerant.
Old Jul 12, 2007 | 06:39 PM
  #47
shafrs3's Avatar
shafrs3
Originally Posted by Overlord
... Like another tech at work says, "I didn't want to learn that today". I'd rather have cookbook directions to follow.
I can definitely appreciate that sentiment...
Old Jul 12, 2007 | 08:39 PM
  #48
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
I tried pulling it out - it came out about halfway and stuck. Should I give it a better tug?
Old Jul 12, 2007 | 08:56 PM
  #49
79vetter's Avatar
79vetter
Yes - it will come out.
