1973 BB Auto - Trans Cooler Lines
Old Jun 19, 2007 | 03:11 PM
L71Swede's Avatar
L71Swede
Default 1973 BB Auto - Trans Cooler Lines
Hello:
Just purchased a set of trans cooler lines from Inline Tube. I am putting them on a car which I purchased incomplete and semi-restored, so I do not know the exact routing and placement of the trans cooler lines under the front crossmember. Car has a TH400 and 454. If anyone has a diagram or photo to share, I would be grateful.
Old Jun 19, 2007 | 04:26 PM
LYLE's Avatar
LYLE
As I recall the they run on the frame bottom just inside the spring. If they are bent correct line up the front and rear and you should see where they go.
Old Jun 19, 2007 | 10:47 PM
L71Swede's Avatar
L71Swede
Thanks - That looks good.
To 1973 BB Auto - Trans Cooler Lines
