Gas Cap Replacement
Old Jun 21, 2007 | 11:18 PM
LBL C6's Avatar
LBL C6
Default Gas Cap Replacement
Went to buy a new gas cap for my 81 and was given a choice of
"Vented" or "Pre Vented".
I didn't buy either.
Anyone know which one I need or does it really not make any difference.
Old Jun 22, 2007 | 08:25 AM
BKbroiler's Avatar
BKbroiler
I wasn't sure which to get for my 77 either. I went with the vented one. No problems.
Old Jun 23, 2007 | 01:56 PM
MN81C3's Avatar
MN81C3
I was told to use a vented cap on my 81.
Old Jun 23, 2007 | 02:09 PM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Just to add to the discussion, does anyone know for sure, does it matter if the cap is vented? What I mean is if the car originally had a non-vented cap, would it matter if it had a vented cap? My car is non-vented right now and I am thinking it should be vented. Can a non-vented cap be made vented correctly, non bubba?
Old Jun 24, 2007 | 07:53 AM
kb2fzq's Avatar
kb2fzq
At the risk of being called bubba (again), I had a pressure problem and the vented replacement cap didn't help, so I drilled a very, very VERY small hole down thru the center of the cap and all is well now...others here will call it bubba...."find the problem, not a bandaid"...I feel it is a fixed problem....just my 2 cents
Old Jun 24, 2007 | 08:07 AM
...Roger...'s Avatar
...Roger...
Old Jun 24, 2007 | 08:36 AM
StickShiftCorvette's Avatar
StickShiftCorvette
I had fought the pressurized gas tank problem for years, despite having a vented cap. The vent in a '69 cap has a spring type disk valve that continually stuck. I finally decided to punch a couple of small holes to provide a positive vent - I didn't want to drill to avoid getting metal shavings into the gas tank.
To Gas Cap Replacement
