Air Compressor help !
Old Oct 27, 2001 | 05:57 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
Default Air Compressor help !
I want to post this here as I feel the C3 forum has very knowledgable members and it is Corvette related because I want to buy a compressor
to work on my '80.
This is what I want it for. AIr tool I will want to run are high torque ( 500ft/lb ) impact gun for those rusted on bolts we're so familiar with, ratchet, drill etc. and I would like to be able to run a grinder/sander non stop and glass bead cabinet, but if that is too costly then what do I need for the impact gun etc.
I was looking at a 6HP 33 gallon compressor at Sears on sale.
Any help would be appreciated .
[Modified by MotorHead, 4:20 PM 10/27/2001]
[Modified by MotorHead, 7:27 PM 10/27/2001]
Old Oct 27, 2001 | 06:16 PM
CF6873's Avatar
CF6873
Default Re: Air Compressor help ! (MotorHead)
Check out the CFM usage of the grinder you want to use and buy a compressor that will deliver almost twice as many CFM's. A compressor should not run non stop for a long period of time. The impact wrench is no problem because they don't run very long at a time, but grinders are real air hogs. Good Luck, Craig :chevy
Old Oct 27, 2001 | 08:35 PM
78Vette-SA's Avatar
78Vette-SA
I have the 6hp 5.5gal Craftsman. It's great with Impact Gun, Air Ratchet, and even an Air Hammer. It works pretty hard with non-stopping sanding and grinding.
I'd be lost without it, but wish I had a bigger one. Especially since I had the 220 line put in for a welder a while ago.
More power!!! :smash: :smash:
[Modified by 78Vette-SA, 7:36 PM 10/27/2001]
Old Oct 27, 2001 | 08:41 PM
Chuck Gongloff's Avatar
Chuck Gongloff
Active Streak: 90 Days
Default Re: Air Compressor help ! (78Vette-SA)
I have an "Industrial Air" 5 HP two stage 80 gallon compressor. Have had it for about 10 years. Decades ago, I started with a tiny one, then got a 5 HP single stage with a small tank, then a 5 HP single stage Sears with a 20 gallon tank. Ran it to death with a glass bead cabinet and/or a sandblaster. Bought the BIG one and have been happy since. Air tools aren't a problem. Blasters use a lot of cubic feet/minute of air. Chuck
Old Oct 27, 2001 | 11:55 PM
kostutsman's Avatar
kostutsman
everyone is right - almost any compressor will be fine when using impact sort of air tools since use time is short but when you transistion to the higher volume for grinding then to blasting the CFMs really put the hurt on a low CFM compressor. Depending on how the bead/sand blaster is setup it can consume 12CFM (cubic feet per minute) so when you make your purchase get the buggest CFM you can afford - big tank size is cool but for longer continous use it's the CFM rating to look at.
Old Oct 28, 2001 | 12:00 AM
ksbunting's Avatar
ksbunting
Default Re: Air Compressor help ! (Chuck Gongloff)
Chuck,
Who do you use and recommend for parts for the 54?
Old Oct 28, 2001 | 06:15 AM
Chuck Gongloff
Default Re: Air Compressor help ! (ksbunting)
Kurt: You have mail. Chuck
Old Oct 28, 2001 | 06:30 AM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
I wish I had listened to this advise when I bought a house-----"Buy the biggest one you can afford!"---you'll grow into it:D Same applies to the compressor.
[Modified by 1970 Stingray, 5:31 AM 10/28/2001]
Old Oct 28, 2001 | 11:15 AM
Tom454's Avatar
Tom454
Default Re: Air Compressor help ! (1970 Stingray)
If you want to save your ear-drums... do not buy the "oil-less" type compressor. I recently heard a brand new (Sears) oil-less and it is very noisy compared to a brand new Campbell/Hausfield cylinder type compressor. Don't get an aluminum pump unless it has a cast iron lining. The noise gets very annoying over time, and I'm sure it can't help the ears.
Also, a heads up on Sears parts- I recently tried to buy parts for my Sears compressor, and the cost of piston rings and a flapper valve was over $200. The compressor was $199 brand new. They lost my brand loyalty.... I switched to C/H.
Another heads up.... if you use quick dis-connect fittings, stick to one source/brand. They may all look the same, but in general are not interchangeable.
And finally, plan on getting a air/water separator.
Old Oct 28, 2001 | 01:28 PM
MotorHead's Avatar
MotorHead
Default Re: Air Compressor help ! (Tom454)
I just bought the top of the line Professional Sears Two Stage compressor
it has 1750 RPM motor and says "quiet operation". It says 5.1 SCFM@90PSI
It has a 20 gallon tank and states 175 max psi but it says because of the two stage it is eqivalent to a 50 gallon at 125 psi. This is one of those shrouded deals with no pullies.
There is another one there that is about the same price and has a separate motor and pump that can deiver 7.1 SCFM @ 90 psi and it has a 30 gallon tank. This one requires oil, has cast iron sleeves etc.
The sales guy said the two stage can supply about five times more air than the ordinary one I was going to buy.
Hey what do I know I'll try it and see :D
[Modified by MotorHead, 11:48 AM 10/28/2001]
Old Oct 28, 2001 | 07:23 PM
MikeC's Avatar
MikeC
Motorhead,
The direct drive compressors are fairly noisy, I have a 5horse devildbiss, and when you are grinding something it gets real annoying, real quick. If you have the extra money get a belt driven one. they are quieter, and built stronger. They will last a lot longer than the direct drive ones.
To Air Compressor help !
