Computer Command Diagnosis Code
Old Jun 23, 2007 | 04:10 PM
Skyhigh82's Avatar
Skyhigh82
Default Computer Command Diagnosis Code
My rear injector is not working. Jumped "A" and "B" and got a code 33 map sensor. It says to "check for open in ground CKT 469"; whats CKT 469?
Old Jun 23, 2007 | 04:24 PM
V-Twin's Avatar
V-Twin
467 & 468 are the injector driver wires from the ECM to the injectors (green and blue, injector ground side), are you sure it's 469?
Old Jun 23, 2007 | 04:27 PM
Skyhigh82's Avatar
Skyhigh82
yup, page 6E-44 service manual
Old Jun 23, 2007 | 04:32 PM
V-Twin's Avatar
V-Twin
the numbers refer to circuits connectors, splices..and so on. Look throigh the computer command & control wiring diagram, the numbers are in there.
Old Jun 23, 2007 | 07:41 PM
DR.Jay's Avatar
DR.Jay
I believe the ground wire is the gray (it could also be black) wire in the harness that goes to the map sensor connector. This wire is also spliced to the throttle position sensor. This wire goes to the (b) connector, terminal pin 11 on the ECM.
Old Jun 23, 2007 | 09:49 PM
Skyhigh82's Avatar
Skyhigh82
I've looked through the entire service manual for 469; it's no where. Could it be a typo?
Old Jun 24, 2007 | 10:53 AM
Skyhigh82's Avatar
Skyhigh82
Thanks for the help it’s working now. I checked the fuses all good then I started a continuity test from the injectors back everything was good to the firewall; still no signal to rear injector. Pulled the connectors from the ECM and checked/cleaned them; still no signal to rear injector. I pulled the fuses again tested them and they were good. Then I noticed the prongs on the fuses were a little dirty looking so I sanded them with 320 wet/dry sandpaper and put them back and both injectors worked perfectly. Man, I’ve been troubleshooting this off and on for a week; I knew sooner or later I’d get it. It was running fine one day then the next not. Thanks for all the help.
To Computer Command Diagnosis Code
