75 Hood induction flap
Old Jun 26, 2007 | 10:03 AM
jotto's Avatar
jotto
Default 75 Hood induction flap
How far should the flap in my hood open? I finally got the WOT switch working correctly so the solenoid in the hood operates the flap and the kickdown is working on the transmission.
At the moment, the flap in the hood moves a very small amount. I assumed it would go from closed ( vertical ) to fully open, ie pivot 90 degrees to the horizontal position.
Can any of you guys with this system go stick your foot on the throttle and let me know how far your flap opens.
Many thanks.
Old Jun 26, 2007 | 10:12 AM
CA-Legal-Vette's Avatar
CA-Legal-Vette
Don't know but am interested as well.
Old Jun 26, 2007 | 02:20 PM
jotto's Avatar
jotto
Just out of curiosity, what years had this as standard and what was the reason for it being dropped?
Old Jun 26, 2007 | 04:00 PM
Corvette ED's Avatar
Corvette ED
From: Pottsville, PA. USA Home Of America's Oldest Brewery Yuengling
I think it was used from 1973 to 1975.
Old Jun 26, 2007 | 04:12 PM
CA-Legal-Vette
Not sure why they stopped doing these.
Probably pretty expensive system between the hood, the air intake, the switches...
Also pretty heavy. Just guesses, but that's probably why it went away.
Old Jun 26, 2007 | 04:13 PM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
I had a '75 and I recall it opening all the way. Here's some other info:
http://books.google.com/books?id=5Ib...dZhkFkmKAW5Rlc
Old Jun 26, 2007 | 04:21 PM
Lon Wayne's Avatar
Lon Wayne
Default Vader Vette
On my test bench the little dude opened totally flat from the up right position.I say test bench because I oiled it up and put it in the drawer with all the other parts Ive taken off bumper stuff mostly. are you trying to get yours to work.I put A 12v red light in place of this little air dam so that when you get the four barrell to work the red light comes on its cool at night looks like fire.
Old Jun 26, 2007 | 04:36 PM
jotto's Avatar
jotto
Jud, great link..thanks.
Lon, thats what I thought should happen. Just before we replaced the switch I connected it to a 12v battery and could here the solenoid clicking and the flap would move a little. With the switch connected it does exactly the same.
I will take it off the hood, lube it all up and get it working...Looking forward to hearing that induction roar Ive heard about!
Sweet looking Vette you have BTW.
Old Jun 26, 2007 | 04:39 PM
LYLE's Avatar
LYLE
It should open all the way to a flat position____ and close to l
Old Jun 26, 2007 | 04:45 PM
75 Red Vert's Avatar
75 Red Vert
Guess I otta get mine working.
Old Jun 26, 2007 | 08:03 PM
LYLE's Avatar
LYLE
The switch is made with the gas pedal under the dash. Many times a short piece of hose over the plastic switch rod will make the system work. The thickness of a floor mat can stop it from working. I think the switch self adjusted the first time you floored it.
Old Jun 27, 2007 | 06:47 AM
Fevre's Avatar
Fevre
I just pulled my whole unit out, full time fresh air.
Old Jun 27, 2007 | 10:11 AM
jotto's Avatar
jotto
Lyle, that is indeed correct. We reset the switch before it was put back in and then pressed the throttle to the floor. This then sets the switch as you said so each time the throttle is floored, it will operate.
I better check at WOT Im getting full operation of the carb whilst I think about it.
To 75 Hood induction flap
